Using some blue Loctite couldn't hurt. My TC has studs and I simply reused the locking nuts and torqued them to 26 ft-lbs. Wouldn't hurt to check the torque on the flexplate-to-crankshaft bolts also. 89 ft-lbs
Also take a look at your starter mounting plate. If you have had any issues with starter bolts backing out now is the time to replace the plate or at least helicoil/timesert the holes. Up-pipes leaking at all? Just some thoughts...
OK thanks guys and sorry for the delay in posting my iphone wont let me post anything. Anyway i have new up-pipes and i will check my starter use because it does sound a little weird .Thanks Roland...yes I have brand new bolts from them so I will torque them and use some blue tread locker.Will it hurt anything if i use some locktite Mark?
