GAS MILEAGE
Old Jan 6, 2012 | 12:52 PM
Brother Les's Avatar
Brother Les
Originally Posted by betsardinski
Thank you all for your thoughts re. gas mileage.
I've certaintly learned that there is a lot more things that can effect my gas mileage, then what I thought.
2003-F-250 - I have 140,000 miles on my truck.
Good point on the increase in Diesel fuel. I'm going to pay attention to the amount of gallons I put in after the automatic shuts off.
I've change the transmission oil as per my manual, but never changed the differential, because my manual says not to. I'm still condsidering changing it though.
RUSCHEJJ - While I've had a number of the points you raised serviced, there are others I haven't, so that must be where my mpg shotages are.
Thank you again to everyone. Hope you have a great day.
Bob
The Fuel tank will hold about 5 gallons more after the first 'click off'. The breather tubes stick down into the tank about 3 inches and the foaming will shut the filler pump off. To fill up to the neck (fuel going into the neck breather tube goes into the tank) you will have to 'dribble' the fuel in and it will take you another 5-10 minutes. Do this several times on fillups in order to check your mileage better. Your console mileage meter NEVER works correctly, so do not believe what it says......
Old Jan 12, 2012 | 09:47 AM
betsardinski's Avatar
betsardinski
FUEL MILEAGE
Thank you everyone for your responses.
I'm fortunate to be down south, so no winter fuel usage and I haven't noticed any clouds at the pipe.
I am going to try the Boost Leak Checker which should tell me a lot.
Have a great day.
Bob
Old Jan 12, 2012 | 10:51 AM
Studawg's Avatar
Studawg
Thread Ender
How are you calculating fuel mileage?
Old Jan 12, 2012 | 03:16 PM
JOHN2001's Avatar
JOHN2001
EBP sensor is hands down one of the cheapest thing your going to be able to check. Ive read about guys cleaning theres on here and have pick up 2-3 mpg that they have lost over the years, theres wright ups on how to do this all over this site. I did it because my best mileage was 16.16mpg EVER!!! Mine wasnt clogged up or even dirty but I figured better safe than sorry and it only took about 20 mins to do
Old Jan 13, 2012 | 07:48 PM
7.3Homeboy91's Avatar
7.3Homeboy91
reading posts like this just make me sick... I get 14.5 no matter what!
Old Jan 14, 2012 | 11:04 AM
JOHN2001's Avatar
JOHN2001
4:10 gears or 4:56 with stock tires will do it every time, plus right now winter blend fuels
tseekins
May 12, 2008 03:38 PM
fordff
17
Jan 2, 2008 08:12 PM
TX76F250
Dec 31, 2007 12:13 PM
5.4Crew
2004 - 2008 F150
Jan 16, 2005 10:23 PM
Gary (UT)
1978 - 1996 Big Bronco
May 6, 2004 05:22 PM
