I have a tranny in pieces that was given to me the tranny code is a T98-1. I cant find anything on this case. It also has w.g. Div and SB1 and below that it has A31-1.
I realize it is a T98 transmission that Novak site comes up with google but what i am wondering is what is it out of? I know they put them in ford trucks and jeeps. With those other markings i want to make sure it is not a jeep tranny im putting in my ford truck. Why do you need to see the bell housing?
i guess my question is what is it from the guy told me it would fit my 51 f1 with the bellhousing he gave me with it.
Tryin to answer your question about the bell housing
Also the T-98 covers a whole range of vehicles - Just giving the information that you gave isn't enough to go on - Kinda like "A guy gave me a horse, what kind is it?"
I had no question about the bellhousing i know what it is i was just including the info that i got one with it . there were alot of different cases and gear ratios for the transmission and i want to know how to tell what mine is with the case numbers i provided so i can put the correct gears back in it and if it is a jeep case i am not putting it back into my ford.
CPR51FRD, it would probably help if you would describe main drive, spline count, length diameter, main drive housing diameter, etc. Also, how about the output, parking brake attachment, driveshaft attachment, etc. Give some further information and perhaps someone will have some ideas. I believe the T98 is the basic tranny that came in several configurations as you have figured out.
Welcome to the forum. Ask a well worded question and many on here will bust our butts to help.
Thanks thats what I needed to know. Ill grab that and ill let you know
and the next question, do you have all the clutch pieces in your truck already - see if you have 1 3/8" 10 spline clutch disc and your T98 is not the same 1 3/8" 10 spline then you have to get a newer clutch disc. Do you have a bellhousing on the engine, one on the trans, is it the split with the big 5" hogshead (the big truck hogshead)...
Hey CPR,
You've kind of come stumbling out of the gate - calling people names who have been here forever. Just relax save the attitude & ask nicely - tons of experience here for those who play nice.
The T98 came in a lot of vehicles - Bryan up above (Brain75) has been writing a huge piece on transmissions - look through his posts. Good luck over there. Tell us a bit about your truck project.
