2012 Oil Pan Change
Old 01-02-2012, 10:39 PM
Sgt93's Avatar
Sgt93
Sgt93 is offline
We have to put oil in these!?!? Son of a.....
Old 01-02-2012, 11:02 PM
Pacman51's Avatar
Pacman51
Pacman51 is offline
No,no,no....we burn oil in these things!
Old 01-02-2012, 11:03 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Originally Posted by mrjc
I just went at looked at mine (2012 built last month) and it is metal painted black with the metal plug. I like the yellow plastic plug.
Now...that says alot!
IMHO...if they are going to make a change...then go the route of cast aluminum with cooling fins. Eliminates the rust issue...but still offers a good cooling surface.
I'm just hoping it wasn't to save a few bucks!
biz
jaybread's Avatar
jaybread
jaybread is offline
Have any of these ever leaked?
It's always about cost in the end. The metal is cheaper.
Old 01-02-2012, 11:21 PM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
Its all about the bottom line and saving a buck...
Thermoplastic Oil Pan (Lower) - MSRP $92.12
Drain Plug For Composite Oil Pan - MSRP $13.32
Oil Pan Gasket - MSRP $10.15
vs.
Steel Oil Pan (Lower) - MSRP $26.68
Drain Plug For Steel Oil Pan - MSRP $5.58
Oil Pan Gasket - Not needed. Uses RTV Silicone Sealant.
The steel pan weighs in about 2 lbs. heavier.
Old 01-03-2012, 12:33 AM
Pacman51's Avatar
Pacman51
Pacman51 is offline
You got to love these oil pan threads......a couple of weeks ago the cliff notes of the last thread was that Ford switched to the composite pans because they were greedy and just wanted to make more money because at the time the speculation was that the composite pan was crap and cheaper to manufacture......zoom ahead to the present and now Ford is greedy and just want to make more money because the metal pan is crap and cheaper!
First off...believe it or not...Ford is in the business to make money! That means that they have to figure out the least expensive way to manufacture thier product and then figure out how to sell it for the most money they can...you know...buy low, sell high! Nothing wrong with that what so ever...... My guess is that it was a combination of public perception of the composite pan being "weak" , vendor problems, and the fact that the metal pan is less expensive to make which lead them to switch.
Old 01-03-2012, 09:01 PM
Big-Sarge's Avatar
Big-Sarge
Big-Sarge is offline
I knew it! My 2011 beast is lighter than a 2012 truck because of my oil pan! Lighter equals faster..right?
Old 03-03-2012, 12:20 AM
Northof62's Avatar
Northof62
Northof62 is offline
My 2012 F250 has the composite pan.
Old 03-03-2012, 07:53 AM
Fulltimer50's Avatar
Fulltimer50
Fulltimer50 is offline
Will the new pan change my towing capacity???
Old 03-03-2012, 08:52 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Tuxedo Scorpion is offline
Just ordered a 2012 PSD 6.7... Was actually kind of looking forward to the composite pan with the 1/4 turn plug. Even tho I wasnt excited about the side mounted plug (purely for mess reasons)... Wasnt too worried about the polymer material as technology definitely can support this material in high stress applications (firearms, pelican cases..etc..)
Im not going to try to speculate why they made the change but i have mixed feelings about it. I presume that if there was a problem with structural integrity a TSB or recall could easily be issued to correct the problem. We all know what were getting into with the metal pan so im not worried about that. Would have been cool to try something new tho. Who knows maybe my truck will show up with the composite...doubt it tho.
2008 F250 Lariat 4x4 6.4 CC 8'box BFG all terrains 2nd radiator
Old 03-03-2012, 12:16 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
If you don't mind...but what is your build date???
biz
Old 03-03-2012, 12:43 PM
Northof62's Avatar
Northof62
I'm not sure. I won't be home until Monday, I'll check. Or is there a way I can find out without actually having the truck or paperwork on hand?
  #28
Old 03-03-2012, 12:59 PM
Thom12's Avatar
Thom12
Thom12 is offline
WOW, Now not only do I have limited edition seats, now I also have limited edition composite oil pan too!! I'm going to run out and get me some LE decals asap! That makes mine a Lariot Ultimate LE 4x4.... Awsome!
  #29
Old 03-03-2012, 02:11 PM
Northof62's Avatar
Northof62
I called the dealer and was told my build date was Oct. 4 2011
  #30
Old 03-03-2012, 03:57 PM
huntindog's Avatar
huntindog
huntindog is offline
I'm pretty sure that was before the switch.
Conratulations or condolences, whichever you prefer.
Quick Reply: 2012 Oil Pan Change
