throttle body adjustment
Old Apr 17, 2003 | 11:33 PM
camarokid81's Avatar
camarokid81
ok i have a 1991 e150 van 5.0 aod. truck has 157000 miles
engine has 17000 and aod trans has 20 miles on it. the throttle
body screw has been moved and i need to get it back to factory position so i can set the new tps.. i have looked every where for this info. people keep saying set tps to .998 ok well i can have the throttle body open 1/8th throttle and set tps to .998 well i know someone knows how to do this and if you you could please enlighten me on the procedure that would be very cool
Old Apr 18, 2003 | 01:43 AM
steve83's Avatar
steve83
This has been discussed, but I'll run thru it the way I learned it:
Warm up the engine, then unplug the IAC. Adjust the throttle stop screw so the engine ALMOST runs, but dies after a second or two. Plug the IAC back in & clear the codes.
IcemanV8
Jun 19, 2014 05:55 PM
bigunit54
2004 - 2008 F150
13
Aug 29, 2013 09:05 AM
llcustom
Modular V10 (6.8l)
Jul 1, 2009 07:59 PM
camarokid81
Apr 3, 2003 01:13 AM
eakanator
Jun 4, 2002 07:03 AM
