Fuel system click
Old Jan 1, 2012 | 08:10 PM
kper05's Avatar
kper05
Fuel system click
A few people here said they’re bored.
So, time for some pointless learning (at least for me).
What causes this fuel system related click at 0:12?
Is something opening or closing?
It comes from under the cab of the truck.
Camera was on top of the degas bottle so it’s loud.
Ford Super Duty 2011 fuel system click - YouTube
Old Jan 1, 2012 | 09:02 PM
Andrew010's Avatar
Andrew010
Fuel solenoid opening?? Hell, do these truck even still have fuel solenoids in the first place?
Old Jan 1, 2012 | 09:14 PM
bigoltrk's Avatar
bigoltrk
Just a guess...intake throttle valve or EGR cycling.
Old Jan 1, 2012 | 09:25 PM
Andrew010's Avatar
Andrew010
Are you sure it's coming from underneath the cab and not the engine compartment?
It could be the low pressure fuel pump kicking on maybe.
Old Jan 1, 2012 | 10:35 PM
EpicCowlick's Avatar
EpicCowlick
I just went out in the garage and tried this. Sitting on the driver seat with the dooropen,I turned on the ignition and listened. 10 seconds later I heard a very similar click from under the truck in the vicinity of the DFCM. I tried to repeat a second time but no sound.
Old Jan 1, 2012 | 10:48 PM
kper05's Avatar
kper05
You have to wait about a half hour to repeat the noise (just figured that out).
The sound is actually louder near the DEF tank now that I've jumped from the cab to listen.
So, further back than I thought.
That squeak you hear at the beginning of my recording does come from the engine compartment but this noise is near the rear of the truck.
Edit: I should say, I waited about a half hour. It could take 5 minutes.
Old Jan 1, 2012 | 11:03 PM
wtrlogd's Avatar
wtrlogd
Can't bring myself to crawl in the mud and listen for said sound, just now, but could it be that the volume is too low on your stereo system?
Happy New Year!
Old Jan 2, 2012 | 08:50 AM
Tom's Avatar
Tom
That's a tough one, kper! I know that the DEF system does a few complex things around this time though. When the truck is shut down it draws all the fluid out from the lines to prevent freezing, and therefore once you start the truck it has to pressurize the lines. There is an injector at the end of the circuit as well as a pressure sensor involved.
Perhaps it has to do with the DEF line filling?
gwcon
6.4L Power Stroke Diesel
30
Nov 9, 2011 06:26 PM
1995_f150
Jul 19, 2010 06:50 PM
javi2001
Dec 30, 2007 07:54 PM
Strokin97
Sep 20, 2007 12:58 PM
k2lee
Feb 25, 2004 11:38 AM
