I am on the road at the in-laws, very limited tools 2 hours from home. I started my truck this afternoon and felt a very noticeable miss or shake. Hoped it would get better as it warmed up....just wishing. Started to drive it to the store and the shake was pretty intense when not under load (meaning not while accelerating). I have a SGII but none of the guages I have programmed are showing any issues. I plan to program in the xguages for monitoring injector misses...any help out there would be great!
Are you able to scan for codes? Any loss of fluids or other symptoms?
yes i do now.. I just set them up and drove it about two miles or so. No misfires are showing up, and I noticed the worse shaking begins when it shifts into overdrive or the highest gear.
I'am with Benny sounds like what mine was doing awhile back when i lost an injector, runs like sh-t don't it . Need to have it scan'ed for codes most likely some there.
Thanks guys! That's what I was afraid of. Obviously noone is open today. I guess I will have to find someone tomorrow. I didn't get anything off the rent-a-puter from the auto parts store. When I did a KOER it came back with a P1780- transmission O/D switch error. Anyone ever heard of that? I don't think that would shake the truck when it goes into O/D would it?
thing is if an injector is dumping fuel in a cylindder it will eventuly burn a hole in the piston or hydrolock it
You maybe able to figure out what injector it is by unplugging them 1 at a time when you get to an injector that has no change when unplugged you found it
all good injectors when unplugged will make it run worse
to bad you didnt get a hit on a code that would be to easy right
If its not smoking Hard like its dumping fuel in overfuel condition you might could get it home IDK thats up to you any smoke and dont do it
this could also be a BAD FICM or Injector Harness try wiggling the injector harness around and see if there is any change
hows the FICM Volts
Guess I shouldnt call a bad Injector just yet
