Power steering pump hoses
Old Jan 1, 2012 | 12:51 PM
1997fordf350's Avatar
1997fordf350
Hi I was Wondering on how do you remove the power steering pump hoses off?
Old Jan 1, 2012 | 01:27 PM
Edgethis's Avatar
Edgethis
The return hose on the pump should just have a hose clamp that you loosen to slide the hose off. It may have a crimped band from factory in which case it'll need cut off and replaced by a hose clamp. The rest of the hose fittings you use a wrench. If these are OEM lines, then the hoses are likely to be rusted together with the steering gear.
Old Jan 1, 2012 | 01:29 PM
tbirdscott's Avatar
tbirdscott
Unscrew each end and it's off really is that easy.
Fitting on the steering box end can be a bit of a pain to get the right angle on but it is doable with just regular open end wrenches.
Scott
Old Jan 1, 2012 | 02:10 PM
1997fordf350
Thanks ill go try that
Old Jan 1, 2012 | 02:29 PM
kd0axs's Avatar
kd0axs
You really should use a flare nut wrench on these fittings rather than a regular open end wrench. An open end will usually work, but many times they will round those fittings off. A flare nut wrench will minimize the chance of rounding them off. If all you have is an open end, go ahead and use it. If they do round off, you can probably get them off with a vise grip.
John7894
Feb 25, 2014 12:58 PM
flip4eva83
Apr 6, 2012 10:13 PM
cheesedog1
Aerostar
Mar 15, 2004 08:44 PM
Stanstruck
Bronco II
Jun 30, 2003 11:01 PM
