585 rpm 295/65 r20s is the largest I could find. Nitto trail grappler mt's Great off road and on road they ride a little like a snowboard. I'm sure they will get better after they wear down a bit. I hope this helps.
Gonna get rid of the no traction Michelins and am wondering what you guys have used and/or recommend.
Am thinking about Wrangler 305 60R20s. 1 inch extra tread width and just barely larger tire diameter. 604 rpm vs 610 rpm.
thanks!
jammer
Are you talking about the Goodyear Wrangler Silent Armour? I had the Goodyear Wranglers Silent Armour and they did well in the snow. But I don't think they were any better than the Michelins. The LT305/60R20 are a 65psi tire, So you will be giving up several hundred pounds of load per tire. If you carry much of a load, such as large gooseneck or 5ver trailers. Probably not a good choice.
I had the 18" tires on my 2006 truck. They were plus sized and were 80psi tires. But I still had problems with them bulging on the sidewalls when I towed a lot. The tires ran great. Just didn't like carrying a heavy load. I had several end up looking like this
Goodyear does not offer a tread wear warranty. At least Michelin does. So if your tires don't last the 60,000 miles they will pro-rate your replacement cost.
If you run around empty. The Goodyears will probably be just fine. But if you load your truck. I would especially stay away from any 65 psi tires.
The BFG All Terrains are a good tire. They have held up really good on past trucks and my daily curb check. These 20" tires are a totaly different animal compared to 16s that I'm used to.
I'm thinking about taking a side grinder to the curb and rounding it a bit.
