Pics or it didn't happen!
Clearly a blown head gasket or cracked head. I've always wondered but never tried, if in that situation filling the cooling system with(waste) oil would help. It would work as a coolant, won't boil, no worries about it mixing, etc.. Sounds like you might be up for trying?
I didn't think the oil cooling properties would be nearly as good as water and a quick google search yielded the following:
Pros and Cons to using oil as coolant - Yesterday's Tractors
Excerpts:
"I have heard that some farmers were using oil in the cooling system instead of water. I can see several advantages to this, along with some drawbacks. Here is what I can think of:Pros:
No rust in the water jacket and radiator.
No freezing and busting of the block.
If you have a cracked block, you don't trash your oil and engine by having water in the oil.
Water pumps stay lubricated.
Cons:
Possibly slower heat transfer to oil than water.
Water boils to remove heat, oil does not, so maybe overheating.
Radiator hoses degrade in contact with hot oil.
Thermosyphon may be slow with thick oil in winter.
Radiator leaks will leave oily spots that don't evaporate.
I'm sure others have views on this. Suggestions? Ideas?"
"The specific heat of oil is about one third that of water. The same amount of heat will therefore raise the temperature of oil 3 times that of water.
The rate of heat transfer from the engine to the coolant is proportional to temperature difference between the engine and the coolant. At the same coolant circulation rate, the oil will be hotter than water and therefore the heat tansfer rate to the oil will be lower. The engine will therefore run ALOT hotter with oil coolant to transfer the same heat generated by the combustion.
One BTU of heat will raise the temperature of one pound of water one degree F while oil will heat up 3 degrees F. If the water heats from 90 to 200 deg F, the oil will heat to 420 deg F. Based on some approximations, yout engine metal parts will run at least 80 to 100 deg F hotter (probably worse).
Also:
1) The maximum temperature of water entering the engine is limited by the radiater pressure. If it is veneted, the maximum temperature is limited to 212 deg F. Oil on the other hand can get to 400 deg F or more.
2) Oil is lighter than water so your water pump, while circulating the same volume (actually less with oil due to higher viscosity), will ciculate about 20% less pounds per minute than with water.
Looks to me like you may reduce cooling side corrosion at the expense of burnning your engine up. Try it and let us know how long it takes to burn up the engine."
Finally getting to work on the storm shelter. Rain has been killing us. We are to the point that rain would wash the sealer off of the walls and mud kept falling in and cleaning it up really slowed things down. But here's the progress. Laying the curtain drain pipe in...
Gravel...
Getting the form walls ready...
Walls in, ready for plywood forms.
Gravel on the pipe.
Gravel...
Gravel on the pipe.
Received 4,179 Likes
on
Those will come out. They are just temporary to hold the form for the 8" of concrete until it sets up. Then it will be open except for the stairs. They go in the hallway looking side. The block cells will have rebar and filled with concrete. The rebar will be bent to go over into the floor. I'll get pics when we do it. The cabin is slowly coming along, rain is killing us. I'll get pics of it when I get back to it.
We are pretty sure it's the head gasket - not worth the trouble fixing. Your idea would be interesting to try. I wonder how long the water-become-oil-pump would last. It would probably be a good idea to at least strain the waste oil before putting it in.
Received 5,351 Likes
on
well done Kman............
on
