Tapping noise from distributor??
Old Apr 17, 2003 | 08:52 PM
90f150moneypit's Avatar
90f150moneypit
Now that the truck ('90 F150 Super Cab with 302/AOD) runs great I noticed that after it warms up there is an intermittent tapping coming from the distributor. I traced it down with a broom stick (the rockers sound fine) so there is no doubt about where it is coming from.
Not sure if it's the distributor, oil pump shaft or the new cam.
Has anyone ever hear of this?
Old Apr 17, 2003 | 09:26 PM
fastf150's Avatar
fastf150
you could have a bad plug or two, and the arcing of the spark will make a tapping noise. if it makes the tapping on a regular basis, try pulling one plug wire off, if still tapping, then reinstal and try another. But be careful as those wires will bite you if you get too close to the ends once they are off or too close to metal. that's my 2 cents.
Old Apr 18, 2003 | 10:38 AM
90f150moneypit
I just put new plugs and wires in . I may pull the distributor today to see if there is any obvious wear.
CaptainJack_7
Nov 5, 2015 08:00 AM
Textureboy
Engine Swaps
Mar 22, 2015 06:59 PM
1979F1504X4
May 23, 2003 03:41 PM
78Bill
Sep 8, 2002 03:03 AM
bsprowl
Sep 4, 2001 03:46 AM
