DANA 60 Disc Brake Conversion? HELP
Old Dec 31, 2011 | 12:12 PM
74ford4x4's Avatar
74ford4x4
Ive bought caliper brackets form Ballistic Fab, using 84 Chevy K20 rotors,calipers and brake pads. My problem is the rotor is like less than a 1/4 inch from the caliper bracket its probably closer to like an 1/8 inch? With it being so close I cant get the brake pad in between the two. Im I missing something or doing something wrong? If I put the pad in there the nut for the hub would just barely thread on loke 3 to 4 threads. THANKS for any help.
Old Dec 31, 2011 | 12:55 PM
dbaerg's Avatar
dbaerg
I assume you are talking about the rear axle? How did you locate the bracket? The best method I can think of is to:
1. Install the rotor on the hub and reinstall the hub on the axle.
2. Bolt the caliper with brake pads to the bracket.
3. slide the caliper/bracket over the rotor and butt the bracket to the axle tube being sure that your brake bleeder on the caliper is pointed up so it will bleed (been there).
4. Use a clamp to clamp the caliper tight to the rotor and weld your bracket.
Old Dec 31, 2011 | 01:00 PM
74ford4x4's Avatar
74ford4x4
They are bolt on brackets, I just bolted them on then install rotor to hub slid the hub and rotor on axle. Yea its on the rear, I dont no what Iam doing wrong Ive looked at thousands of pictures and it all looks like mine, accept the rotor being so close to the caliper bracket
Old Dec 31, 2011 | 01:10 PM
dbaerg's Avatar
dbaerg
Does your rotor have the correct offset to it?
I found this youtube link in my disc brake conversion research archive:
How To Dana 70 Disc Brakes - YouTube
Other than that, I don't know what to tell you. That's the big trick about doing non-standard mods. You just have to get creative and make it work.
Old Dec 31, 2011 | 02:24 PM
74ford4x4's Avatar
74ford4x4
Iam using 84 k20 4x4 rotors, is there a different year I should try or use?
Old Dec 31, 2011 | 02:37 PM
dbaerg's Avatar
dbaerg
Does Ballistic Fab recommend a rotor? Otherwise, the rotors used in the video are from a 78-79 Ford Dana 60 front axle.
Old Dec 31, 2011 | 02:43 PM
74ford4x4's Avatar
74ford4x4
All the articles Ive read have used chevy parts? I notice the video did is ford rotors. I wonder if they have a different offset like you said? Have to look and see if I can find deminsions on the rotors. Thanks for the help!
Old Dec 31, 2011 | 02:48 PM
74ford4x4's Avatar
74ford4x4
Just looked Advance Auto has the 79 ford rotors in stock. I might have to run over there and see if there any different from what I have.
Old Dec 31, 2011 | 02:58 PM
dbaerg's Avatar
dbaerg
Ok, autozone shows the dimensions under the part details, but you'll have to convert to metric.
Old Dec 31, 2011 | 03:57 PM
74ford4x4's Avatar
74ford4x4
The ford rotors are 1/2 inch thicker than the chevy rotors. Ford rotors like 6 1/2 inches tall on hub the chevy rotor on hub is like 6 inches. Iam not sure how to fix my problem. I dont see any diference in my setup than the videos.
hunt1moore
Jun 9, 2014 05:07 AM
randallsdaddy
Aug 23, 2011 11:28 AM
jleal_21
Apr 2, 2010 08:37 AM
VoodooRacer
Mar 26, 2009 11:52 PM
jdawwggin25
Feb 4, 2005 03:00 PM
