scangage
Old Dec 31, 2011 | 03:40 AM
busdriver47's Avatar
busdriver47
Question scangage
when my truck is cold the oil temp is about 2 degrees highter than water is this right
thanks
Old Dec 31, 2011 | 07:59 AM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
After a 12 hour cold soak, the fluid temps should all be the same or very close. You can change the "math" on the X-Gauge to adjust the temperature readings.
Old Dec 31, 2011 | 08:09 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Does you EOT read with a decimal below 100*? How about the f*WT (ECT), does it have a decimal reading?
You might find you are closer together than you think. And depends on length of sitting.
Mine right now, after sitting 2 days, with current ambient of 35*f, ECT is 37*, EOT is 38.7*.
Since I do not have a decimal in the ECT, I would like to believe I'm closer to a 1* spread, than a 2* spread.
Old Dec 31, 2011 | 06:06 PM
busdriver47
my ect does not have a decimal point.My eot has one
4CFarms
Jun 16, 2011 12:12 PM
mater78
20
Feb 22, 2009 10:51 AM
61 uni
Dec 22, 2008 05:05 PM
tndiesel
19
Dec 31, 2007 06:58 PM
2002f2507.3LPS
22
Dec 25, 2006 12:53 AM
