running boards help
Old Dec 30, 2011 | 09:23 PM
Rosson03's Avatar
Rosson03
running boards help
well a while back no one wanted my running boards so i put them back on on i havent had them on in 6 years. wow i know. i have own my ex fo 9 years. woo hooo!
anyways. i have put them on and only one side are working... i have taking the dust spray like u would use on key boards and still nothing. i have a couple fuses are burnt out. ineed to go to he store and get some fuses.
do u think there are 2 fss for each side or what!!!
thanks
Old Dec 31, 2011 | 08:53 PM
Rosson03's Avatar
Rosson03
NO ONE!!!!!
Old Dec 31, 2011 | 09:34 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Rosson03
Anyways, I have put them on and only one side is working. I have taken the dust spray like you would use on key boards, and still nothing. I have a couple fuses (that) are burnt out. I need to go to the store to get some fuses.
Do you think there are 2 fuses for each side or what!!!
thanks
When you say only one side is working, you're referring to the running board lights, correct?
If yes, then I'm pretty sure (not 100%) that it's only one fuse for the running board lights.
If you have a volt meter, check to make sure you have power running to the side without lights. It's possible, though not probable, that all the lights burned out on one side.
Stewart
Old Dec 31, 2011 | 10:07 PM
robert_l_ross's Avatar
robert_l_ross
The running boards on Excursions (and Expeditions) are known for having light issues. The water runs down the board and collects around the light sockets and/or the light sockets don't keep a good seal and moisture builds up inside. That corrodes the sockets eventually ruining the sockets.
My Expy didn't have this issue, but my Excursion had it when I bought it. The sockets (reflector, lens and socket/bulb) are replaceable, $15 for two - here is a listing:
Running Board Lights - Ford Excursion/F150 (Alpintech) RB-3000A | eBay
I have a few photos of them installed and they are great - maybe even a touch brighter than stock.
Bugzilla46310
Aftermarket Products
Jan 26, 2016 08:47 AM
Jenkins6586
May 12, 2011 08:18 AM
myblkex
Apr 8, 2009 08:26 PM
cobramustangboy
Appearance & Dress-Up
Apr 22, 2007 03:32 PM
GreenHornet79
Apr 10, 2006 04:56 AM
