Sponsored by: Real Truck
topping off PS fluid
Old Dec 30, 2011 | 05:21 PM
kruzer's Avatar
kruzer
I have to top off my fluid. It's just below the stick when the engine's cold. Can I get it from a parts store like in a brand like a mobil or valvoline or need I get it from the dealer. I know it's a ATF, at least I think I do.
Old Dec 30, 2011 | 06:01 PM
shorebird's Avatar
shorebird
The container will say Power Steering Fluid on it.
Old Dec 30, 2011 | 06:08 PM
dchamberlain's Avatar
dchamberlain
All of the recent year trucks I have seen (as far back as Dad's '96 anyway) spec Mercon ATF as power steering fluid, but you might check your Owner's Manual to be sure, since you don't say what year.
Any Mercon compatible fluid should work.
Old Dec 30, 2011 | 06:27 PM
Firefighter 1406's Avatar
Firefighter 1406
I lot of guys run mobil 1 syn ATF and it helps quite the pump down also. $8 bucks a quart is expensive but well worth it.
Trigger
Jan 18, 2025 10:05 AM
mlelah
Oct 1, 2011 05:48 PM
5.8F250
May 11, 2011 05:30 PM
kntryboy
1997 - 2003 F150
Nov 27, 2005 06:07 PM
BigMattXXL
Oil & Lubrication
Dec 11, 2002 06:16 PM
