12mm x 1.75 pitch (at least this is what I've consistently found while searching)
You win Roland 12mm 1.75 pitch is correct. Now to the car wash to blast it off a little and back to get it mounted up and get that core HPOP off T500 is ordered. Then I have to find a core sheet. I cant get the link to download from Clay. Might have to get ahold of Joey I guess
Yep 1.75 does it. I was just going to pull the HPOP for my core, buuuuuut I could not stop heads are off. Cylinders dont look to bad one piston has a little damage on the top of it not sure what could cause that. I also remembered that I got all the turbo stuff with that motor plus an extra turbo that looks much bigger than the other one it is a Garrett but the fins dont look to good on it. need to figure out if I have everything to update my E99.
I did not realize how big injectors where. wow.
thanks again all
thanks for the heads up. I am planning on a complete rebuild. Goal is around 400hp. with alot of new goodies. Gonna have to look good as well when I am done.
