middle row not latching
Old Dec 30, 2011 | 09:53 PM
Skip1970's Avatar
Skip1970
well it sounds like your doing it right, but theres allot of directions them levers can go, and several levers. very confusing setup for some folks. i noticed your from scottsdale so i know the heat might have got to your head some this last summer.
Old Dec 30, 2011 | 10:00 PM
Ghadaz's Avatar
Ghadaz
You know it.
Old Dec 30, 2011 | 10:05 PM
Skip1970's Avatar
Skip1970
maybe if you could post pictures of the handles and levers and what way your pushing them , that would help out.
Old Dec 30, 2011 | 10:14 PM
jasonodsky's Avatar
jasonodsky
You've been a sport about this so far...glad you know how your levers work
I'll see if I can dig up some pics with the lever system. I seem to remember some of the levers are under the track that's bolted to the floor. Could be much easier if you unbolt the seat. Let me find the pics first.
Old Dec 31, 2011 | 03:01 PM
jasonodsky's Avatar
jasonodsky
OK, flip the seat base up, like you were folding it for cargo. This will expose the latching mechanisms at the base. You will see the release cable running side to side at the base of the seatback. There are two metal rods with a slight S bend running on top of the tracks (front to back).
Now that you can see the rods, flip the seatback release rearward like you were trying it to get in. Tilt the seatback forward and watch to see if both rods move. The two rods should move in unison and slightly backward when you tilt the seatback forward. If one or both don't move, it is likely a problem in the release cable. If they both move, look at the track releases below the two covers at the front of the tracks. There are levers there. Could be one of the rods or levers have become disconnected.
Old Dec 31, 2011 | 03:21 PM
jasonodsky's Avatar
jasonodsky
Here is a pic with the parts and descriptions. Please excuse the kid crap
Old Jan 3, 2012 | 01:01 AM
Ghadaz's Avatar
Ghadaz
Thanks jasonodsky
As soon as I get some free time with daylight I will take a closer look.
I lifted the seat bottom that first night but didn't really know what to look for. Just sprayed wd40 in there hoping it would solve the problem.
I will keep you posted on what I find.
Thank You.
Old Jan 3, 2012 | 02:33 AM
robert_l_ross's Avatar
robert_l_ross
Do you think those S rods could cause the reverse problem (when the seat back is folded down, it sticks and won't come back up)?
Old Jan 3, 2012 | 02:35 AM
Skip1970's Avatar
Skip1970
get it fixed soon, ive been tossing and turning at night thinking about it, make it your 2012 resolution.
Old Jan 3, 2012 | 07:23 AM
LivingLarge's Avatar
LivingLarge
You are just too funny! Maybe if all else fails he can try your pattented Scotch tape repair!
Old Jan 3, 2012 | 09:17 AM
Treker58's Avatar
Treker58
Jason have you removed the plastic cover to see if the track release is actually working as it should, mine was hard to move forward until I removed the cover and lubed the release parts up, when you slamed it back and finally got it to latch you may of jammed it locked somehow
Old Jan 6, 2012 | 12:26 AM
Ghadaz's Avatar
Ghadaz
Jasonodsky, thanks for the pics.
I have discovered that my latch release rods do not budge when the lever is pulled back and the seat back flipped down. If I manually pull those rods back, the latch will release and allow to move the seat back and forth.
What part inside actually controls those rods? what piece should move to move those rods back?
Old Jan 6, 2012 | 12:30 AM
  #28
robert_l_ross
Don't they have plastic clips on the ends to attach them to the lever and mechanism? I see one in that pic...are they intact and fastened?
Old Jan 6, 2012 | 12:44 AM
  #29
Ghadaz's Avatar
Ghadaz
I'm not even sure. I will try to take some pics or maybe a video of the moving parts tomorrow.
Old Jan 6, 2012 | 01:06 AM
  #30
robert_l_ross
I think the yellow circle shows one end with a plastic clip...did the other end have one maybe?
