Hey guys, My 2004 6.0L f-350 has been having some issues. Took it to ford and they diagnosed the egr/oil cooler is shot and needs to be replaced as my truck is spewing white smoke from the exhaust, overheats really easy, and the coolant keeps coming up empty....
---- please note, I haven't touched the internals...its bone stock under the hood----------------
After some research, I have come up with/been instructed (thanks to EODguyJake) on what to get in terms of replacement parts.
I need yall to just double check it and confirm Im getting the right parts or if I have left anything out.
I figure I will order all the parts then take my truck in to just a standard auto/truck repair shop. Do you think they will be able to do all the installs and such or should I take it to a diesel truck shop?
Lastly, I have been told to have the heads checked to see if they need machining...can this be done at a basic auto repair shop or do I need to go somewhere special?
Anything else I am missing? Thanks in advance for your input/advice
I just got done doing my heads studs oil cooler egr delete and a few other things. I had to do some research to find a machine shop that was able to skim the heads. I was told it takes some kind of special equipment. I would ask around allot of machine shops that dont work on the 6.0 heads know who does. I personally would not have your average mechanic work on your 6.0 but I guess that depends on how well you trust your mechanic. I would try to get a recommendation from someone on here. I would have them get new injector 0rings I bought mine from ford, and after found out they dont come with the D-ring in the top. IIRC Riffraff has a oring kit that has the d-ring. It looks like your missing the gaskets in your list. Definately have your heads checked by a reputable shop. Plan on getting all new fluids and filters. If you want that oil cooler to last you might want to invest in a coolant filter at some point.
