No start/rough start HELP - Arrrgh!
Old Dec 29, 2011 | 11:02 PM
Equus_Blue's Avatar
Equus_Blue
We have been struggling with our truck for about 10 days now. It was shutting down, like you turned the key, after starting and running for less than 2 minutes. After extensive reading ont he forums and manual tests we replaced the CPS, ICP sensor, alternator, and finally broke down and bought the Auto Enginuity scan tool. These are the codes we are getting:
P1316
P1483
P1298
P1293
P1294
Any help would be GREATLY appreciated!
Old Dec 29, 2011 | 11:18 PM
BigAlsPSD's Avatar
BigAlsPSD
Have you cleared these and these are the codes that come back? the 1298 IDM failure doesn't sound good, then bank 1 and 2 high side opens, have you tested the wiring?
GB_Tech_Bulletin_103_Ford IDM_Module_Replacement.pdf
Old Dec 30, 2011 | 10:09 AM
tdpower's Avatar
tdpower
You can look up codes here: Welcome to guzzle's Diagnostic Trouble Code list Web Page
Sounds like a possible idm failure. Do the checks Alan posted. Try to do an injector buzz test that should retrieve any codes stored in the idm. With the 1293 and 1294 you may not even be able to perform the buzz test.
Old Dec 31, 2011 | 02:48 PM
Equus_Blue's Avatar
Equus_Blue
I have yet to convince hubby to pull all the stuff out of the way to check the UVCH wiring. It is very frustrating because if the truck sits (say overnight, or all afternoon) it will fire right up with no error codes. Go out an hour later and it either won't start, start rough, or start and die with a plethera of errors. We have run through the standard checks of fuel heater, fuses, unplugging sensors. He will be pulling the fenderwall off to check the IDM and the those stupid UVCH wires today if I have to stand over him with a whip!
Old Dec 31, 2011 | 07:16 PM
PaysonPSD's Avatar
PaysonPSD
You don't have to resort to S&M.
The 1316 is an IDM code as well. Can be caused by Burned Center Pin even if there is good continuity at UVCH. Something you can also make him check.
Old Dec 31, 2011 | 07:51 PM
Equus_Blue's Avatar
Equus_Blue
Well the drivers side was loose, passenger side was good. Shimmed them both the handy-dandy quarter. No change. Cranks, sometimes catches/runs/dies, other times no go.
I think we are going to start over and re-check everything. fun fun!
Old Dec 31, 2011 | 07:56 PM
PaysonPSD's Avatar
PaysonPSD
Wiggle the different sections of the engine harness if you can get it to idle. Might point you in the right direction if it idles smoother or rougher.
Also check the nut holding the IPR solenoid and see if there is oil in the ICP sensor connector. You can also just unplug the ICP sensor connector to see how it runs.
Old Dec 31, 2011 | 09:13 PM
F350-6's Avatar
F350-6
Jena, get your AE out and run a buzz test when the truck has been sitting a while and you think it will probably start. Clear all the codes then start it up and let it stall and run the buzz test again. See if you hear the same buzz sounds and what codes show back up after the stall.
After it stalls, if you try to re-start it, is there any smoke coming out the tailpipe while cranking?
Old Jan 1, 2012 | 02:07 PM
Equus_Blue's Avatar
Equus_Blue
Well this afternoon the truck started just fine, no codes and clear buzz test. We are letting it run to see if it will stall out.
Old Jan 1, 2012 | 03:49 PM
Equus_Blue's Avatar
Equus_Blue
Cool
The truck ran great for over an hour. Drove around the block, uphill, downhill, reverse, etc. finally had to shut it down. restarted just fine. no codes, buzz test fine again. shut it down, put tools away out from under hood, took a break. Now it won't start. P1298, 1294, and 1293. ????? WTF???
Old Jan 1, 2012 | 06:49 PM
HD Rider's Avatar
HD Rider
It's looking like you have a failing IDM (Injector Driver Module).
Old Jan 2, 2012 | 11:14 AM
PaysonPSD's Avatar
PaysonPSD
If there is no white smoke while cranking then the IDM is not firing the injectors.
Too rule out low batteries make sure there is 10.5 volts while cranking. If not then the IDM wil not fire the injectors. Low cranking volts may have given you the IDM codes.
Old Jan 2, 2012 | 06:25 PM
Equus_Blue's Avatar
Equus_Blue
No white smoke. Went out this morning/afternoon, truck started up and ran great, no codes 3 times in a row. Did some errands around the farm (no truck use), came back to it and it won't start again. Batteries check out good, new alternator, so went and bought new batteries just in case. Still won't start. Just pulled the IDM. All pins looks good, wiring continuity good. This is getting very frustrating!
Old Jan 2, 2012 | 08:32 PM
F350-6's Avatar
F350-6
Since you've got AE, lets watch some live data next time you get a no start. On the live data tab, watch engine RPM, battery voltage, ICP psi, ICP duty %
Also, since it seems to start and run fine, then not, try unplugging the ICP sensor next time you get a no start to see if that helps.
Old Jan 2, 2012 | 08:57 PM
Equus_Blue's Avatar
Equus_Blue
This is what we got:
RPM peaked at 291
ICP 2278 PSI at the same time, peaked at 2374
ICP DC % 34.8, that was peak as well
Volts 10.9, that was its low
ICP unplugged made no difference
second recorded attempt
RPM ~175
ICP low 2200's
DC% 33.6
volts 10.9-11.1
