The top pic is the charcoal canister purge valve. Hooks to vacuum anywhere and then hooks to top of vapor canister. Just set it aside or tie it somewhere. Not really nessisary.
The second one is the smog pump valve. Puts air either into cat or into heads.
It's vacuum operated so the solenoid that controls it (I think by the coil) is unplugged and ecu shows no resistance so throws a code. Check that out and let us know.
Thanks!! So with the purge valve plugged in (but not connected to the intake or purge tank) that code went away. Also located the smog pump valve, and plugged that in. On one end it's connected to manifold vacuum and the other end is capped.
The truck no longer has a cat or air pump.
Reperformed the KOEO test and it passed!
Performed the KOER test and it passed.
Still sounded like it wanted to cut out at idle, but at least I know two things aren't working with is the purge and the Air Injection. Though the air injection I knew previously.
I'll take it out for a good run today, and let you know how it goes.
So I think the next things on the list are a thermostat and water pump. It still has it's weird idle problem though, but only in gear. Does anyone know if that year C-6 had a lock up torque converter? Or if the torque converter could cause it to feel like it has no power occasionally? I know it's got a major tranny leak, and it drives a whole lot worse when the fluid is low. Wondering if the low fluid level so often might have caused some damage somewhere in the trans or TC that is causing some of my issues. Maybe time to rebuild it.. What do you think?
Oh and the water pump/thermostat is because at idle it sits at 190, and when driving it creeps up to about 220 230, which I realize isn't good, but as soon as I'm back to a red light, the temp drops again. This only started happening after I majorly overheated it (bout 250) driving around in 4 lo on the beach with 65 psi in the tires! It was struggling!!!
Check and see if your radiator is plugged. Externally and internally. Overheating while driving and not while idling is odd. Normally with more airflow over radiator it cooks better. What this is telling me is that radiator is compromised and extra load of driving cant keep it cool.
Pick up a 195 thermostat, drill a 1/16 hole in the flange (air bleed) and swap out the wpump like you want. Impeller could be toast and not circulating well. If you're not gonna try to reuse the coolant then put in some flush and run it a bit. Then rinse with water and replace items you want.
Radiator is new. When I replaced it I vacuum filled the coolant system. It held pressure and vacuum for a while. So I don't think it's the Radiator. It may be a head gasket or something, but I haven't checked to see if the cylinders are leaking down.
This truck may just have one too many problems to still consider saving. Sad, but between the body work, and engine/driveablity items going on, I think it may be more than it's worth to fix. I hate to pass it and all it's problems on to some one else though, and I do love this old truck.
Flush the system ( cooling) on my 1988 460 I pulled the block drains and nothing came out ! They were packed with rust and garbage inside the block , poked them with a screw driver and all the muck poured out . I then proceeded to rinse the block out with the garden hose . My truck does weird things when it gets hot , as the day progreses . I've wrapped the injector rail in a heat reflective tape which helped . The other thing I did was to move the air charge temp sensor out of the intake and extend the harness so the sensor is in the air box . The truck seems to have responded better with more power . It's a heat related issue with these things . So as long as the cooling system is clean and the coolant temp sensor is working correctly it should run ~ better ...
What parts have you replaced so far.
I'm going to say maybe you're tfi module is bad or the cat is plugged. Weird how it acts up when hot and not cOld. That's a sign of a bad pickup of module. But also it's in warm run mode. Cat plugged should hold it back all the time but when cold the ecu has the fuel richened.
I'm guessing now. But you may need to throw more parts at it.
Being in ca is the truck mass air. Could be dirty maf sensor or leak in the intake tube maf to tb.
I am getting a new Catalytic Convert tomorrow.
I took it to a garage by my house(I think this guy is now going to be my new mechanic)
He looked at it drove it around on a test drive. Was gone about 25min. He went up and down the streets in the area. He came back and said yep the cat is blocked.
Will keep you all posted.
That's good news. Let me know what you find out. On another note, I decided to rebuild the transmission. It was leaking and shifting hard. Just picked it up from Aamco this afternoon. Told me that it was full of metal and not a single valve in the valve body would move. Think this could definately cause a problem.
They also noted that their was no coolant in the system. Yeah seems that when I heated it over on the beach, i may have just forgotten to put more coolant in it.. I shouldn't drink so much maybe I'd remember to take care of the details...
Truck runs a lot better but it still blogs down. Cat was plugged.
I am going to a mechanic that I know that's retired from Ford Motor Co. He worked at a Ford dealer here in San Diego. He thinks it might be a bad Map sensor.(even though it was replaced less than a year ago.)
He said he can test it with out a code reader. (he said he doesn't trust them, made in China or Japan wants to use a digital voltmeter) he said he has all of his Ford Manuals from when he went to work for the Dealer until he retired when they sold out.
So here we go again pour more money into it. I could have put a new crate motor in it by now.
I understand the feeling. At least when I throw parts on her, she has some new pieces that should last a few years. Though everyone keeps stating that the get bad parts that cause problems, it doesn't seem to be my case. I've had good luck with Pep Boys, AutoZone and Advanced.
But I am still the most happy with the transmission rebuild. I believe that fixed most of my issues. It's not slowing down, stalling out at lights any more. No more sticking it in neutral and keeping the RPM's up at a stop light.
Next is making sure the coolant system is working right. It's going a little weird still. Heating up while on the highway, though slow speed driving and idling seems ok. Anyway, busy weekend but hopefully I'll get the chance to start the testing on the coolant system. Thank God they haven't changed how these things work compared to the new cars. At least it'll be a simple diag on that.
Get rid of the Bosch Platinums. Put in stock Motorcraft plugs and wires. There have been a lot of guys through this forum that have had problems with gizmo plugs.
Jason
I agree. I switched mine out for Motorcraft, except for one that kinda broke off. Damn beer again, making me think the air ratchet would make things faster!!! I've got the new one in the truck now, but it doesn't seem to be helping much sitting in the back seat!!!
Jason
I have to agree, I have always only used the OEM plugs. In my 63' Galaxie 500xl with a 427 cid wedge motor. (it was my Dads car when I got my dl he gave it to me and then he got a Shelby GT-350. I used Champion but that was in the early 70's & 80's
Well I got my Truck back today. I went and got on the freeway put my foot in it and was doing 90 mph by the end of the on-ramp. I got off the freeway at the next exit. There is a steep hill and the truck ran like a raped ape!
I replace the Ignition Control Module Part #DY1077.
It was also out of timing. Adjusted from 6 to 10 BTDC
The shop also put it on a Dyno runs great.
Glad to hear you finally got to the solution~!
I found this post due to the fact that I just bought a 94 450 460EFI and it has what seems to be a VERY similar problem. I may just bite the bullet and start first where you ended up. Many thanks, and enjoy your ride!
~Brian/Hurlmetal
Well I have had my truck back for two weeks today! It still is running like a raped ape!
If I didn't know better I would think it had a brand new crate engine in it!
Thanks for all of the suggestions.....I think that maybe the best one was I should have found a new mechanic before I did 2 weeks ago.
I really think I was making his payroll for the last three years.
I kept a list of the codes, in my notes about the problems, low and behold in last year 2011, I took my truck to my old mechanic, and told him the code was 212, he said okay. (then it started) he never replaced the Ignition Control Module. But he started throwing parts at it. I guess we live and learn.
