1987 High idle
1987 High idle
hello, i just got through putting together my engine after having a valve job done but my poor truck is idling way to high. she doesn't have a tak but im geussing its idling somewhere in the 1.5k range. my buddy and i think its a vaccum leak but ive spent days trying to figure it out. please any help would be great.
Genaraljjw
make sure you have double checked all vacuum lines, tubes and sensors. I cannot stress that enough.
Mustang LX Throttle Positioning Sensor ( TPS ) Voltage - YouTube
Ok someones gotta ask might as well be me, the throttle/throttle cable/pedal, is it setting against its stop screw fully returning to the closed position?
If so and it idled right before getting tore down for the valve job then yea I agree, vac leak.
You've checked all vac lines associated canister etc, and checked the throttle body/EGR/IAC etc etc gaskets yea? well then that pretty much leaves the intake gasket/s as only thing left.
Chuck / hank
07-03-2011 09:53 AM
dewjr_72
03-31-2007 04:26 AM
Brett7715
07-06-2006 08:29 PM
