motorboating
Old Jul 1, 2011 | 06:01 PM
Chuck / hank's Avatar
Chuck / hank
motorboating
motorboating is what I call it but my truch idols up and down constantly. Ive always associated it with a vacuum leak. However I can't seem to fix it. ANY suggestions? I have a 1985 F-250 with a fuel injected 302
HELP
Old Jul 1, 2011 | 06:11 PM
Shark Racer's Avatar
Shark Racer
I wouldn't be surprised if you have a vacuum leak, it can be real sinister with EFI.
Could also be a stuck/sticking IAC.
Listen to all of your injectors too.
Old Jul 1, 2011 | 06:21 PM
Archion's Avatar
Archion
Veteran: Marine Corps
It can be made worse if someone has tried to adjust the idle speed. That changes the TPS voltage.
Old Jul 2, 2011 | 08:39 AM
Franklin2's Avatar
Franklin2
1st thing to do is take the throttle body apart and clean it with carb cleaner. Clean the idle air motor also, but don't get carb cleaner on the motor itself. Put it all back together and get it running. If it still does it, unplug the idle air motor while it's running. If it still is idling pretty high, adjust the idle stop screw till the engine is barely running about 500 rpm or less. Then turn it off, plug the idle air motor back up and re-start it. Rev it a couple of times and let the computer "learn" to control it, and see if the problem finally goes away.
Old Jul 2, 2011 | 10:54 AM
Shark Racer
Is there also a method to reposition the TPS sensor? Along with a point to grab base(idle) voltage from?
Old Jul 2, 2011 | 12:05 PM
Franklin2's Avatar
Franklin2
If the TPS is adjustable(some are not) it's done with a voltmeter on the TPS wires. As was previously mentioned, you should not touch the idle stop screw, but by the time they write in, it's too late for that. A certain amount of air is supposed to go by the main butterfly, and the rest goes through the idle air motor passages. 90% of the time, the butterfly is coked up with carbon, and that disturbs the air balance.
Old Jul 3, 2011 | 09:53 AM
muscletruck7379's Avatar
muscletruck7379
the tps has three wires running to it, a reference, a signal, and a ground. if i remember right the signal is green. you want to backprobe it (jumper wires or it needs to be plugged in, key on) and then slightly loosen the screws and twist until you get as close to a .99 volt reading without going over .99v
I find it easer to do the adjustment with the throttle body unbolted from the intake, as its on the bottom. but thats ok cause your gonna clean it right?
