2012 6.7 transmission shift programming
Old Dec 28, 2011 | 03:53 PM
JOHNWSC's Avatar
JOHNWSC
Hello,I was wondering if any could help with a trans question.I just bought a f250 with the 6.7 ,6 speed auto.I was wondering if there was any way to program the trans so when you come almost to a stop the trans doesn't go all the way down to 1st gear.I find when that happens the motor rpm's have to rev up to catch up with the trans being in 1st.If it were only to go down to 2nd
gear that would be perfect.I can understand if you were starting from a dead stop you would want to start in 1st especially towing,but this motor has so much power that when your not towing I would be happy if 1st didn't exist.
Thanks for any help
John
Old Dec 28, 2011 | 04:56 PM
ruschejj's Avatar
ruschejj
You can use manual shift mode or go through the trouble to lock out first gear each time you start the truck using the +/- button.
And for future reference, you don't have to make a lot of noise in this forum to get some attention. Hopefully a moderator will consolidate your 3 topic threads. Everyone here will be happy to help you even if your question refers to how to best clean your windshield. Search for it if you don't believe me.........
I just think you will get used to it. At first it takes a while to get a feel for the engine. Also, the TCM is learning your driving style so it should even out some as you drive it.
Old Dec 28, 2011 | 05:22 PM
JOHNWSC's Avatar
JOHNWSC
Thank you.
I wasn't aware my topic posted 3 times.I made 3 changes to it not knowing it reposted every time.I will try to delete the other 2 if possible.
Old Dec 28, 2011 | 06:46 PM
ruschejj's Avatar
ruschejj
Originally Posted by JOHNWSC
Thank you.
No worries, I'm not shooting a shot across the bow. Just want you to know this is a great forum. Sometimes folks get stressed out and go nuts with posting hoping to be the loudest voice and then hoping to get fast replies. I know it happens on other forums so I just wanted you to feel welcome.
Unfortunately, I don't think you will find a permanent and convenient solution to your issue. I hope somebody here has the magic solution though.
Old Dec 28, 2011 | 07:29 PM
kper05's Avatar
kper05
In auto [D] mode, you can only lock out higher gears, 6,5,4,3,2.
Can't lock out 1st gear.
However as ruschejj said, if you're using [M] mode and you allow the transmission to downshift on it's own, it will stop down shifting at 2nd gear.
I'm also assuming they've not changed the programming from the 2011 models.
For posting topics/posts, don't use your web brower's backspace feature or you'll end up submitting duplicates.
Submit the post then use the edit link/button under your post to make changes.
Pastor Scott K
Oct 28, 2018 10:24 PM
667Litre
Mar 27, 2014 02:57 PM
JOHNWSC
6.7L Power Stroke Diesel
Dec 30, 2011 07:43 PM
izzybird
Jul 8, 2010 09:14 AM
thinksnow
Mar 15, 2009 05:56 PM
