Powdercoated Spindles
Old Dec 27, 2011 | 05:56 PM
dmt_73ford's Avatar
dmt_73ford
Just got my spindles back from the powder coater and found that they sand blasted the opening in the back of the spindle that the kingpins ride in. I seem to recall this channel being smooth when I pulled it off the truck. My new kingpins are the nylon bushings type. Do I need to worry about that channel being too rough? Thanks!
Old Dec 27, 2011 | 07:06 PM
HIO Silver's Avatar
HIO Silver
'Not sure what you mean by "channel". Do you mean the holes in which the bushings and kingpin are installed?
Old Dec 27, 2011 | 07:25 PM
dmt_73ford's Avatar
dmt_73ford
Yes, the holes in which the bushings and kingpin are installed
Old Dec 27, 2011 | 07:57 PM
HIO Silver's Avatar
HIO Silver
It depends how rough they are. I mean, the sleeves are machined and the bushings are fitted as to not allow grease behind them.. However, the nylon bushings have bigger channels on their insides for the grease and provide lubrication.
Assuming the bushing grooves are bigger and allow more grease through than the rough surface, then ya should be okay. Again, it depends how rough. I'd prolly call up a machine shop and ask them. If they say it's toast, then I'd make the powdercoater pay for replacement spindles AND do a TON of powdercoating for free.
egg collector
Oct 9, 2013 08:51 PM
66f-100
Apr 14, 2010 05:58 PM
Nick_Good
Mar 2, 2010 06:06 PM
whalerron
Nov 3, 2004 05:53 PM
Fat Fendered Ford
Jan 21, 2004 10:52 AM
