Speedometer is Wrong
Old Dec 27, 2011 | 10:54 AM
50th ann's Avatar
50th ann
My 2010 F-150 Lariat speedometer is reading fast. About 10%. It's an all stock truck I bought new. Currently has 41,000 miles on it with orignal tires and no other troubles at all. Can these speedometers be adjusted or do they have to be replaced?
Any Help Will be Appreciated
Old Dec 27, 2011 | 01:58 PM
MCDavis's Avatar
MCDavis
Factory settings tend to be 3-5% off, with the speedo usually reading faster than your actual speed. 10% seems high. What were you comparing the speedo to? GPS?
Also, what speeds were you checking this at?
You say that the truck is stock, but are your tires factory sized? What is your tire size?
The computer can be reprogrammed. The dealer will usually only change to accomodate other factory size offerings. Aftermarket hand held programmers will allow for additional changes, usually.
In the end, just be happy that it's 10% faster than actual speed, as the opposite could land you a pretty nice ticket.
Old Dec 27, 2011 | 02:28 PM
50th ann's Avatar
50th ann
Speedometer is wrong
The tire size is P265/60R18 which matches the label inside the drivers door. I am comparing it to a GPS that was right on the money with my previous 1998 F-150 and the roadside radar signs that display your current speed. I might be reading 42 MPH and the sign says 38. The faster the speed the bigger the difference. At 70 MPH I'm showing 80MPH.
Old Dec 27, 2011 | 02:47 PM
LxMan1's Avatar
LxMan1
Your dealer can calibrate it. It is all PCM controlled off of the speed sensor.
Old Dec 27, 2011 | 05:56 PM
NoMo's Avatar
NoMo
The other side of that is that his warranty is also 10% less than it should be.
metru
Nov 8, 2017 09:26 PM
klr650goldwing
May 23, 2016 10:41 AM
Technologiq
May 29, 2013 08:42 PM
Navyguns
Aerostar
Jul 19, 2010 08:38 AM
EB03PSD
Jan 18, 2007 01:44 PM
