6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR Delete Install
Old Dec 30, 2011 | 08:38 AM
RM2738's Avatar
RM2738
Originally Posted by slowmans
yes, but you can make your own for a fraction of the cost.
Now that's my kind of project. Would you happen to know where I can get a parts list and instructions?
Old Dec 30, 2011 | 09:41 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by longview1
I hear ya,
Now am I able to use that same block off plate closer to the turbo or do I need to fab something up? ...
I used the cooler block off plate & tapped it to
1/4" pipe thread to hook my exh back pressure
Sensor line that j made, up via a compression fitting.
I bought a 5/16" steel brake line, cut one end off to use
the flare nut off the stock EBP line.
I cut the Exhaust pipe into up top & cut the bottom into from
Underneath to get it out.
Old Dec 30, 2011 | 01:52 PM
bnmccoy's Avatar
bnmccoy
If you look at the first page of the "Air Management....." in the 6.4 diesel coffee table book or 6.4 bible there is a good drawing of the exhaust piping at the rear of the engine.
http://www.forddoctorsdts.com/articl...eTableBook.zip
The above link is from Ford Doctor's site which has lots of good information.
Bob
Old Dec 30, 2011 | 02:49 PM
bnmccoy's Avatar
bnmccoy
https://www.powerstrokediesel.com/do...ble%20Book.pdf
another link to the whole 6.4 coffee book
Old Dec 30, 2011 | 08:07 PM
longview1's Avatar
longview1
Banned
Thanks for the link bnmccoy.
Old Apr 8, 2012 | 08:01 PM
wem0221's Avatar
wem0221
I just removed my pipe lso and just used the blockoff plate that came with my egr delete kit. But the problem i have is the truck has low power so i guess I will have to install the back pressure sensor into the blockoff plate as well. I took the sensor and plugged it up and tie strapped it to harness but truck runs like crap now
rlanicek
6.7L Power Stroke Diesel
17
Nov 5, 2015 07:50 PM
Pickupman2004
May 9, 2014 04:33 PM
diamondrcattle
Jan 22, 2014 01:35 PM
PattonC222
Feb 23, 2013 05:20 PM
bigrodge8
Nov 4, 2009 10:27 AM
