Radiator Core Support Bushings Replacement
Old Dec 26, 2011 | 10:56 PM
Rick_Fury's Avatar
Rick_Fury
Can the rubber bushings under the radiator core support be replaced without removing the entire radiator core support from the vehicle? Mine have dried out and are starting to come apart and I would like to replace them. I looked under the truck, and it seems like I should be able to place a jack under each side of the core support and take the long bolt out from under the bottom, and then the bushing and shims should be able to slide out.
Has anybody ever done this?
Old Dec 27, 2011 | 07:53 AM
Grubbworm's Avatar
Grubbworm
Yes, they can be removed without removing the whole radiator core support. If you look at the LMC catalog, you can see how they go together. LMC Truck Parts - Page 22
Good luck. And I would recommend using the poly-urethane bushings.
Old Dec 27, 2011 | 10:24 AM
Rick_Fury's Avatar
Rick_Fury
Thanks, Grubbworm. Am I right that you can jack up the front of the support on each side just enough to replace them?
Old Dec 27, 2011 | 10:47 AM
Grubbworm's Avatar
Grubbworm
Once you get all the hardware out of the way, they are not that difficult to replace. As I recall, I just used a pry bar to give me enough clearance to slide the new ones in place. You may have to replace some of the parts, depending on how worn or rusty they are.
I have some pictures of when I did mine.
Old Dec 28, 2011 | 12:02 PM
4x484150's Avatar
4x484150
I had to replace both the top and bottom bushings, and the brackets for both sides. Got all the parts from Ford. I jacked up the support, and used a measured 2x4 to hold it up while I worked. Also had the truck in gear and parking brake set on flat ground.
Old Jan 10, 2012 | 10:34 PM
LARIAT 85's Avatar
LARIAT 85
What brand of poly-urethane bushings did you go with, Grubbworm?
Did you notice any difference over the stock rubber bushings?
Old Jan 10, 2012 | 11:58 PM
bruno2's Avatar
bruno2
The core support bolt is threaded through the top bushing(big one, is threaded in the center) and it is nutted on the top side of the core support. There should be some shims in there on each side. Be sure to get everything back in like it came out. I will be suprised if you can get the bolts out w/o any trouble. Especially the ones on the batery side.
Beofre you button everything back down take a look at how the hood sits as well as the gap between the hood and fenders. The core support is made to mov every which way to line that stuff up.
Old Jan 11, 2012 | 07:51 AM
Grubbworm's Avatar
Grubbworm
I used these; energysuspension.com | Welcome
Yes,. I do notice a difference over the rubber bushings. For me it seems like a slightly stiffer ride and a little better handling. My wife doesn't notice the difference between the rubber and poly, other than it rides better now. But, for both my wife and me it feels like it rides better than when it was new. If you are worried about the ride, then I would do the cab bushings in rubber, and the rest of them in poly. Personally, I like the way it rides with the poly. It rides like a truck should ride...Like a Truck, not a car.
Old Jun 21, 2024 | 12:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I know this is an OLD thread, but, I want to ask y you have to remove the batteries to change those bushings?
Thanks in advance
Old Jun 21, 2024 | 12:28 PM
Max Capacity's Avatar
Max Capacity
I'll guess, because the bolt could be under the battery mount tray ? Isn't one of the bolts behind the vent canister ?
Old Jun 21, 2024 | 02:28 PM
Bronco638's Avatar
Bronco638
Looking at my '80 F-150, I would say that no, you do not have to remove the battery (batteries?) but it might be helpful.
Old Jun 21, 2024 | 02:58 PM
Max Capacity
Ok, you made me go look. All you need is a long extension, a deep socket and maybe a universal joint or wobble extension. Good luck, mine looked pretty rusty. I did that area with fluid film a short time ago.
Just make sure your ratchet doesn't hit the battery terminal...
Old Jun 25, 2024 | 01:02 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thank you for your help and comments, I forgot to mention that my truck is a F250 1996, and has two batteries, and I found this thread, looking for more info. thanks again. best regards amigos.
johnny19
Oct 29, 2018 09:14 PM
FordmanShane
Aug 10, 2012 11:07 PM
Rick_Fury
Dec 27, 2011 10:26 AM
smokeyb97
Mar 2, 2009 09:11 PM
