Slow Return to Idle
Thanks in advance
Cbass
A vacuum leak will cause a high idle. You might try to disconnect and plug all the vacuum lines and see what happens.
If no vacuum leak then you can start looking at carb adjustments. Look at the idle set screw and see if where its at. Does it look likes it cranked way in? or is about normal looking? Its possible that the idle mixture screws are way out of whack.
Sometimes its a real pain to balance the adjustments between the idle mixture and the idle set screw to get the truck running where it should
Bobby
It might be necessary to start over from square one. What happens when you run the idle mixture screws all the way in? the truck should die. If it doesn't then either the idle set screw is too high or there could be a vacuum leak.
You could run the idle mixture screws all the way in and then back them out approx 1 1/2 to 2 turns and start from there. Start the truck and see if it will idle, tweak the idle set screw some trying to keep the idle approx 700 to 1000 rpm. Then start runing the idle mixture screws in 1/4 to 1/2 turn at a time, go back and foth between the teach side. Again, you might have to adjust the idle set screw while doing this. Run the idle mixture screws in until the engine starts runnign rough and then back them back out a bit until it smooths out.
If you have a vacuum gauge, hook it up to manifold vacuum, adjust the idle mixture screws to maximize the vacuum.
Be patient, go back and forth between the idle mixture and the idle set until you get it dialed in
Bobby
) but I'll also add a few worthless comments. You should be able to kill the engine if you back off the idle screw enough. If you can't, you may have a mechanical problem. If you need to physically grab your linkage and yank on it to reduce your RPM that's a problem. Possibility #1
Idle/Air adjustment and Vacuum leak as my good buddy Bobby said is also a factor but Idle/Air Adustment is a fine-tune, A massive vacuum leak will cause high idle and is not something you can adjust for. Possibility #2
Any seal-point going into the intake manifold should be examined.
Good Luck
Dawg-A-Roo
I just did a screen capture so I can right click and save....WOOOHOOOO!!
I got something right, I got something right, I got something right (picture fat guy doing a happy dance) I got something right...
LOL....the key is to be patient and try and not get frustrated, a frosty beverage might come in handy at several points in the process.
Good to hear from you Dawg!
Bobby
Thanks
Cbass
Is there a easy way or what is the way to check the butterfly for alignment and damage?
Cbass
The butterfles should be at a slight angle with nice clean edges all around.
If you see a big air gap between the butterflies and the carb throat then you definately have the idle set screw adjusted too high.
Vacuum leaks can sometimes be a pain to track down. Start with the obvious, look at vacuum lines, are they old, cracked, dehydrated? They are cheap, replace them. Does your truck have power brakes? sometimes the diaphragm in the brake booster will develop a leak.
Unplug and cap off all of the vacuum lines. If you still cant get the truck idling right then its time to start looking at gaskets; carb, intake, etc. You can diagnose those by spraying some carb clean around the gaskets and see if the idle changes significantly.
I once bought a 73 Olds from a kid for $75 bucks cause he couldn't get it to run right. After I paid him I popped the hood and looked at the carb. The poor kid had bolted the carb back on the engine with the bracket for the accelerator cable between the carb and the intake manifold...LOL. He had created a huge vacuum leak. I loosed the front bolts on the carb, pulled the rear bolts, moved the bracket from under the carb to on top of the carb and bolted it all back together. Started it up, quick adjustement and drove it away.
Bobby
Bobby
Cbass, am I also correct that 2300's have a power valve just like the old 94's?
