Ross, power valve that was changed last spring to match the vacuum I was getting and because it was torn. I hope it isnt that again, would rather not have to take it off the truck again. I dont have power anything so the only vacuum line is to the dizzy so I will take a look at that and see if I need to replace it. I will be checking for the usually leaks with a can of cleaner, almost hope it is something like that and thus I can fix it during my week off of work starting tomorrow.
Thanks again guys
Cbass
That is what I put in it (I believe, would have to look it up to be positive), the truck came from florida and I went with what ever the Holley rep. that I spoke with on the phone said would work best. I am not a carb expert but I can follow directions, that is why I love this site. Keep steering me in the right direction and I will get there.
May sound crazy but after it warms up check to make sure the choke is opening correctly. My truck has a manual choke and until I back the choke back off after starting, it will not idle down. ( my is a holley carb )
Is that one of the carbs that prone to tearing a power valve when you get a backfire?
If he only vacuum line you have is a ported line to the dizzy then its probably not the source of your vacuum leak....it would only have vacuum on acceleration and not at idle.
....but....does the carb have a big open hole in the rear of the baseplate.....maybe where a 3/8 line once ran to a power brake booster on a different application?....maybe that would be plugged off? (I once dealt with that on a friends car as well...LOL)
Take a windex bottle and put some dish washing soap and water in it and spray around the base of the carb and around all lines, if you have a vacumn leak it will suck the soap suds and u can find the leak. Be sure to spray around the throttle shaft because they can leak also, Garry
Got it running great thanks to a lot of great advice. I just started over after making sure there was no mechanical problems (butterfly, linkage, choke) but the return spring was a bit weak to I replaced it and then started tuning from step one by vacuum gauge. I got it so that girl is running better then it has since I have owned her. The obvious things that needed fixing were the accelerator pump was adjust wrong (even after that is what I did over the weekend) and the idle screws were out too far. Not sure it was any one problem that caused the bad idle or just the combo of all of them but thanks to all that helped our.
Regards,
Cbass
Excellent!!
I'm glad you got it dialed in. There's been many a time when I've been totally frustrated trying to get somthing to run right. Sometimes you have to walk away for a day or two and then start from scratch.
