Sponsored by: Real Truck
timing or fuel?
Old Dec 26, 2011 | 04:14 PM
Gadget5061's Avatar
Gadget5061
timing or fuel?
I have a 1999 F350 V10 gas. The truck is absolutely running like crap. It lopes up hills and runs extremely labored. At an idle it seems to be OK, whenever it has a load on it, it drags. severe engine miss.
My friends have debated over whether it is a timing problem or a fuel problem, I recently installed a new fuel pump and filter. This did not help. We then learned that the exhaust was VERY hot and somewhat shallow. I have to admit that it's symptoms say Catalytic converter, but neither me or my mechanic friends believe that will be the problem. Both exhaust manifolds have blown gaskets. We felt that due to the impossibility of changing the plugs, that some may have been bad, causing the fuel to burn in the exhaust. I paid Ford $750 to change the 10 plugs and check the coils. No luck. Does anyone else have similar issues? This truck starts with the turn of a key and purrs- until you put it in Drive.
jbancroft
Jul 10, 2014 09:12 AM
Dimitri13
Sep 3, 2013 10:36 PM
Steelheader87
May 13, 2012 09:50 AM
17Z
Aug 31, 2010 10:46 AM
boston2k4
3.8 & 4.2L V6
Aug 25, 2006 01:09 PM
