Husky floor liner question
Old Dec 26, 2011 | 11:58 AM
srkr's Avatar
srkr
Do the husky liners have the two buttons on the drivers side to hold them in place?
I sure do want the ford ones...my rubber superduty mats already have a heel hole in them. Was just gonna replace the fronts..but ny if they snap in place.
Thanks,
Shane
Old Dec 26, 2011 | 12:21 PM
jack_pine's Avatar
jack_pine
I am pretty sure the weather techs do.
Old Dec 26, 2011 | 01:05 PM
ruschejj's Avatar
ruschejj
My weather techs have two raised circle impressions where thos two buttons go. They don't do anything but cover them up. I don't know about the husky ones though.
Old Dec 26, 2011 | 01:38 PM
wiedsworld's Avatar
wiedsworld
Husky does not have the two post latches, just a bump up to cover them. However, I will say that the drivers side mat fits so perfectly that it barely moves. Very impressed with it. The passenger side one does move more, but not bad. The back seat mat fits well.
Old Dec 26, 2011 | 02:40 PM
2000silverbullet's Avatar
2000silverbullet
This ^^
My 2 complaints are that the pass. side doesn't sit flat up by the floor heater and the center piece (I bought the 3 piece front set) doesn't "integrate" with the driver/pass. pieces (it doesn't hang over the driver/pass liners cleanly).
Old Dec 26, 2011 | 03:02 PM
cford716's Avatar
cford716
I have the Husky mats. I agree with the 2 posts above, drivers side and rear are great. Only disappointment is with the pax side. It has a high side that runs up the heater and does not sit completely flat. Overall very happy though.
Old Dec 26, 2011 | 03:22 PM
jack_pine's Avatar
jack_pine
My weather techs in my Honda hook to the floor, but only because I cut holes to do that, my bad i forgot (just looked at them again)
What I would really like is something to cover all of the carpet to protect from the dog hair. If I could shrink wrap it I would.
I do like the depth of the weather techs because of the sand at the cabin.
Old Dec 26, 2011 | 06:26 PM
ruschejj's Avatar
ruschejj
If it helps, the weather tech is very similar to the husky in that the driver and rear mats fit very well but the passenger floor one does move around. I have to say that it fits well enough, just nothing around to keep it firmly planted. I'm very happy with them.
And jack, there is a plastic product that construction folks use to cover carpet while finishing a home or building. I think it would work well for you but I don't have any idea what it is called. You will find it on new carpet before the occupancy permit/inspection is finalized.
Old Dec 26, 2011 | 06:55 PM
Tomahawk's Avatar
Tomahawk
Shrink wrap the dog?
I just use an old king size sheet that goes over the headrest, covers the entire seat and the floor.
Old Dec 26, 2011 | 07:43 PM
Dim Sum's Avatar
Dim Sum
I have the Huskies as well and the floor mat clips do not go through on the driver's side, but there are two reliefs in the plastic mat. (I have the weather beaters)
I like them.
Next are the Husky mud flaps
Old Dec 26, 2011 | 07:44 PM
smallcandle's Avatar
smallcandle
Go with the Husky Weather Beaters. They fit far better than the classic liners and still have the plastic nibs on the back to grip the carpet and keep them from moving about.
Old Dec 26, 2011 | 10:36 PM
cford716's Avatar
cford716
I should clarify that I have the Husky weather beaters, those are the ones I was talking about. Again, very good, just minor issue with the pax side.
Old Dec 27, 2011 | 05:37 AM
2000silverbullet
Same here, my comments were directed to the WeatherBeaters as well (part #'s 98711 & 83671).
Old Dec 27, 2011 | 07:02 AM
kper05's Avatar
kper05
I recommend the Husky weatherbeater liners.
These have saved my carpets more than once and keeps the dirt, mud, water, snow (when we get it) within the liner.
Might not fit as perfectly as the super duty factory mats but they get the job done.
Old Dec 27, 2011 | 07:34 AM
reelnut's Avatar
reelnut
Floor mats
You may want to look at Fox Weather Boots great floor cover...
