Engine Issues
Old Dec 26, 2011 | 02:02 AM
BigD7575's Avatar
BigD7575
Engine Issues
i am having a problem with my engine. i step on the pedal and it seems to stumble for fuel the engine shacks rough and as soon as i let off it, it stumbles hard again and almost dies but catches itself and continues to run rough. just replaced hpop and ipr and it did not help. has smoke coming out of crankcase vent and seemed to have oil seeping out of the dipstick tube. have no clue if its icp, fuel pump, fuel lift pump, debris restricting pickup in fuel tank, idm, valve cover gasket, injector pigtail or if i'm down an injector. any ideas would be greatly appreciated
thank you
Old Dec 26, 2011 | 02:37 AM
BigD7575's Avatar
BigD7575
just wanted to add that it has white smoke out the stacks at all times, no matter cold or warm
Old Dec 26, 2011 | 07:58 AM
DIYMechanic's Avatar
DIYMechanic
Does the white smoke smell like fuel or sweet like brown sugar? It almost sounds to me like a blown head gasket although these trucks don't tend to have head gasket issues.
Old Dec 26, 2011 | 08:01 AM
DIYMechanic
Try this, with the engine idling, take the oil filler cap off, turn it upside down and set it back over the fill hole. Does the pressure inside blow the cap off or does it just sorta rattle around on there?
Also, have you checked the fuel pressure or fuel filter? How about the FPR screen?
csutton
22
Feb 1, 2013 08:06 AM
onehandedbandit
Mar 31, 2011 09:48 AM
ccg711
22
Sep 10, 2006 11:42 PM
ash308
Dec 20, 2005 02:55 PM
gdavis2265
Apr 26, 2003 01:42 PM
