DO I REALLY NEED BOTH..... WHAT WOULD HAPPEN... WILL IT BE A REALLY "TIGHT RIDE" LOL HA HA HA I MADE A FUNNY..... WELL I FOUND THEM FOR $358.88 INCLUDING SHIPPING AFTER ajgn03 COUPON CODE AT JCWHITNEY.... IS THAT A GREAT DEAL!!!
Rosson - All Excursions came with a front sway bar, so if yours is still there, there is no reason to replace it, it's a good sway bar. The problem is that most excursions did not come with a rear one, and for most applications they could seriosly use one. Those excursions that did come with one (only '05s IIRC) came with one which is regarded as a bit too small, and the Hellwig is pretty universally reported to be a big improvement. If you have a stock factory front sway bar, leave it alone, you are good to go there and would be wasting your money. Just get a Hellwig for the rear.
Someone else on here may be able to tell you if they have found a better price, but J.C. Whitney is where most buy them, and that sounds about right price wise. I doubt that you will find them much cheaper.
