PSI AND STAT QUESTIONS
Old Dec 25, 2011 | 07:44 PM
Rosson03's Avatar
Rosson03
Has anyone have any ideal whats the psi for the Radiator. i would like to buy one of those Mr. Gasket ThermoCap Radiator Caps after i put in my jet thermastat. Mr. Gasket 2470B Mr. Gasket ThermoCap Radiator Caps
anyone has tried the jet thermastat:
2000 EXCURSION V10 147000 miles:
K&N 57-2524-2 air intake, BBK Dual 65mm throttle body, Jet Mass air flow, Jet spacer, Royal purple engine, Royal purple trans, Royal purple rear diff, Fitch Fuel Catalyst. Hawks SD brake pads, front and rear, Drilled and slotted rotors, took off my luggage rack, removed that big black rubber piece under the hood, ditched the running boards, took out the 3rd row seat and bass system
Old Dec 25, 2011 | 08:42 PM
archtaan's Avatar
archtaan
Its 15psi I believe for the diesel. Not sure if the V10 is different?
Rosson03
Dec 25, 2011 09:20 PM
Rosson03
Sep 26, 2011 05:19 PM
Rosson03
Sep 24, 2011 07:55 PM
Rosson03
Aug 22, 2011 05:56 PM
ggadwa
Jul 2, 2001 02:43 PM
