Positive 6.0 Experience
Old Dec 25, 2011 | 03:41 PM
paulm's Avatar
paulm
With all the stuff I read in the 6.0 forum being negative I just thought that since my 2007 F250 just hit 137,000 I would post the problems I have experienced. The truck is used predominately for towing. Oil changed every 7,500, fuel filters every 15,000, coolant every 60,000.
29,000 mi - front axle pinion seal leaking - covered under warranty
60,000 mi - replace air filter
90,000 mi - replace batteries - $170
125,000 mi - check engine light comes on during 7,000 mi trip from TX to SC to NM back to TX. Replaced egr valve - cost $190.00.
135,000 - replaced brake pads and air filter.
Current mileage 137,177
Old Dec 25, 2011 | 04:11 PM
bismic's Avatar
bismic
Congratulations! I bet you have no significant issues for many more miles!
Old Dec 25, 2011 | 05:29 PM
King-bRanch's Avatar
King-bRanch
Wow that is great...I hope my newly aquired 2006 (110k) is a realiable one (ill be doin all proper maintance)
My dad bought a 2004 new (which is now over 100k) & other than a new exhaust system has only required a new EGR Cooler. Hell he doesnt even do proper maintance (so he's been lucky). They are not all bad...
Old Dec 25, 2011 | 06:44 PM
MobeyDick's Avatar
MobeyDick
I think I have you beat by a long shot. 05, 4X4 Reg cab, 160,000 miles, I've replaced the Belt Tentioner @ 138k, Belt, Batteries twice, original Air Filter and original coolant until just recently. I just had (last 1,000 miles) to replace the SCT fitting and while I was there I put the sinister EGR Delete kit on it. 10,000 mile oil changes and 30,000 fuel filter changes. I flushed the Tranny at 148,000, no other service to it. I’ve had minor issues with Interior trim AC vents Radio.
Old Dec 25, 2011 | 07:09 PM
BLADE35's Avatar
BLADE35
Awesome you had a great experiance
The Folks that take there time to go thru this site and understand a little bit about 6.0 and its operating systems Fare way better to have a reliable truck.
From time to time I see folks come here to complain about Ford and Bad mouth the 6.0. Those folks are sometimes causing there own Greif by not taking care of it Properly.
Old Dec 25, 2011 | 08:05 PM
freedomfarmer's Avatar
freedomfarmer
Belt tensioner is that what's making that little sgueling up there?
Old Dec 25, 2011 | 08:37 PM
gunnarGSD's Avatar
gunnarGSD
If you think about it, three of those five are maintenance items and not really problems.
Old Dec 25, 2011 | 09:29 PM
MobeyDick's Avatar
MobeyDick
The pulley was freewheeling, the Tentioner wasn't "Flexing" I noticed the AC pulley would squeal when I turned it on and it wasn't working well.
Old Dec 25, 2011 | 10:02 PM
zhilton's Avatar
zhilton
Exactly; any other truck/car/van/suv air filters, battery(ies) and brake pads are considered something you normally replace. But for some reason in the 6.0L world it's just something else "wrong with the truck". I don't have the overall mileage...but I've got you beat on the batteries & air filter. We'll see if the pads make 125k...only 18k to get there (fall of next year at my current yearly mileage).
Old Dec 25, 2011 | 10:12 PM
firedaniel's Avatar
firedaniel
My 06 has 201,000 just did the oil cooler and egr... Shes been great! Been learning how the engine works and fixing things before they become major issues.... Love it!
Daniel
Old Dec 26, 2011 | 12:03 AM
dukie1877's Avatar
dukie1877
yeah buddy good goin glad to hear it.
Old Dec 26, 2011 | 03:02 AM
highteckredneck's Avatar
highteckredneck
from what i hear only 02-05 6.0 were crap, in 05 the redesigned the engine with international and it has been a good enigine since, i just hope my new toy holds up like yalls.
Old Dec 26, 2011 | 06:06 AM
F-250HD's Avatar
F-250HD
I disagree, my '04 has been faultless, no failures in 133K when I bought it, I ran the OASIS..............clean sheet!
I just did all the preventative maintenance and reliability mods, EGR delete, new oil cooler, Flush/ELC, coolant filter, CCV mod, clean turbo (was working fine) new belt,
blue spring in regulator, 6.4 banjos, new Thermostat. All new Motorcraft filters, Rotella 5W-40 T-6
I'm ready for another 150K...................
Old Dec 26, 2011 | 07:50 AM
bismic's Avatar
bismic
IMO the rep that the early 6.0's got (they didn't make an '02 model) was largely due to some quality control issues at the factories and lack of training (troubleshooting, etc) at the dealerships. Yes there were issues w/ the early ones, but they were largely good engines then as well as now (again IMO).
Ford did make improvements: They made injector longevity improvements, suspension and brake system upgrades, HPOP changes, water pump changes, and the most needed - sensor and wiring/connector upgrades. Still they lost ground in the arena of HPO system leaks with the 05 upgrades and the redesigned EGR cooler was shown to be way less robust. Software improvements and EGR system improvements happened for most model years.
Know the weaknesses and address them and you will be rewarded.
I know people shy away from the term "bulletproof", but improvements can be made and they don't have to cost an arm-and-a-leg.
Old Dec 26, 2011 | 08:54 AM
MobeyDick's Avatar
MobeyDick
I also just put a Fuel pressure Reg kit on, the keyhole gasket was pressed flat after 158,xxx miles.
