straight 6 engine rattle
Old Dec 24, 2011 | 12:16 PM
cmb2481's Avatar
cmb2481
I have a 1994 Ford F-150. When it is turned upon, it makes a rattling noise that sounds like its coming from the alternator or power steering pump. I'm not sure, since I don't know a whole lot about vehicles. Any suggestions? The rattling starts as soon as the vehicle is turned on, but is very consistent throughout the whole time the vehicle is operating.
Old Dec 24, 2011 | 02:45 PM
Harte3's Avatar
Harte3
The source of a noise is nearly impossible to diagnose over the internet. It could be any number of things. Raise the hood, start it up and see if you can determine the source and/or have someone familiar with vehicles help with that in person.
Old Dec 24, 2011 | 03:27 PM
351M's Avatar
351M
One way to tell if it is the alternator or PS pump would be to remove the Serpentine belt and start it. If the rattle remains it is in the engine itself, also once the belt is off try spinning the alternator, waterpump, ps pump etc.
Old Dec 24, 2011 | 05:55 PM
jem44357's Avatar
jem44357
Check the belt tensioner, the part you use to loosen the belt for removal. I had one on my '93 go bad. You may be able to lube it.
Jim
Old Dec 26, 2011 | 09:02 AM
Tote-M-Pole's Avatar
Tote-M-Pole
Get a stethascope thing from Harbor Freight, around $10. You can hear a bad bearing quite easy. Just be carefull not to get it wound up in the belt.
techningeer
Mar 25, 2014 11:37 AM
btpoole
Apr 9, 2012 10:05 PM
Tim Clinton
Aug 24, 2010 08:53 AM
Kathy1
22
Aug 14, 2008 11:01 PM
masseysbronco
1978 - 1996 Big Bronco
Jul 30, 2007 04:09 AM
