I have a 1992 f150 4x4 extra-cab long box. It is the 155 inch wheel base. I have the 5.8 with the E4od trans and the B-W 1356e trans case.
the problem I am having is with my drive line. At the joint behind the carrier bearing the teeth on the male end of the spline are almost gone for some reason. and I cant find a new or used drive line for the 155 w/b here so will the front section off a 134 w/b work or are they different lengths to. Please any feed back will help need the truck next weekend to move my son back home.
