I am in the prosses of changing trans lines to 3/8 line I need to change fittings on trans ? is on return side there is a fitting with a ball and spring (check valve) I would assume, do I need to replace it with same type fitting to accept larger male end on 3/8 line or can it be eliminated? Only function I can see is that it restricts flow back to trans by a little bit not much tension on it. Thanks and hope all are having a great day.
