more 47 questions
more 47 questions
The heater in my 47 2 ton was removed and I have a box of parts, I have no idea how they are assembled and I'm not getting any clues from the firewall. Does anybody have a exploded parts view of it? Also I can't get the fan motor to work. It has 4 red leads coming out of it and it's likely 6 volt. Can these be rebuilt and converted to 12 volt? Any help is appreciated.
Heater Question
Heaters were often added later. Typically the heater frame holds the motor and fan shroud and mounts to the firewall with two bolts. The heater core is supported within the shroud and has two water pipes that will pass through both the motor frame and firewall. If you can't match the four holes in the firewall chances are the heater may never have been installed in your truck.
Usually you only have one wire from the motor and this is hot. The motor is grounded through the frame. The hot wire goes to a rheostat heater switch to vary fan speed. Maybe the four wires are for a two speed switch using two ground connections. Check out using a 6V battery. If motor doesn't turn, it may be gummed up or the brushes worn down.
Peter
Peter
I rebuilt and re-installed my heater not too long ago, let me see if I can link the pictures for you..
<a href="http://s1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/?action=view&current=DSCF0071.jpg" target="_blank"><img src="http://i1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/th_DSCF0071.jpg" border="0" alt="Photobucket" ></a>
<a href="http://s1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/?action=view&current=DSCF0072.jpg" target="_blank"><img src="http://i1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/th_DSCF0072.jpg" border="0" alt="Photobucket" ></a>
<a href="http://s1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/?action=view&current=DSCF0074.jpg" target="_blank"><img src="http://i1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/th_DSCF0074.jpg" border="0" alt="Photobucket" ></a>
<a href="http://s1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/?action=view&current=DSCF0076.jpg" target="_blank"><img src="http://i1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/th_DSCF0076.jpg" border="0" alt="Photobucket" ></a>
<a href="http://s1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/?action=view&current=DSCF0968.jpg" target="_blank"><img src="http://i1097.photobucket.com/albums/g349/newold46/46%20Ford%20rebuild/th_DSCF0968.jpg" border="0" alt="Photobucket" ></a>
You should be able to see where the hoses and bolts go through the firewall on the last picture.
Heater Question
Peter
Wow, those parts are nothing like mine. But thanks for taking the time to post the pics! At least I get an idea where the hoses go through the firewall ( even though those holes don't exist on my firewall.
There's a discussion on the heaters here:
https://www.ford-trucks.com/forums/1...ck-heater.html
You can use the 6v motors in a 12v system. Just need a heavy duty resistor to drop voltage (and dissipate heat. They have big heat sinks)
Good luck on your project!
jazz1
Jan 5, 2012 01:54 PM
e william
Nov 15, 2010 01:24 AM
dagwood387
57
Jan 24, 2010 07:07 PM
e william
Oct 26, 2007 09:11 AM
