73-79 Leveling Kit?
Old Dec 23, 2011 | 11:45 AM
jeepjinx's Avatar
jeepjinx
73-79 Leveling Kit?
Old Dec 23, 2011 | 12:41 PM
ChaseTruck754's Avatar
ChaseTruck754
These trucks (2wd) are expensive to level due to the kingpins in the ibeams not having any way to adjust the camber after changing the ride height.
Autofab Offroad Trucks has 2wd kits for these trucks. They cost a lot but are good quality for sure.
Old Dec 23, 2011 | 01:33 PM
montana_highboy's Avatar
montana_highboy
....and finding a shop that still does it is virtually impossible.
Old Dec 23, 2011 | 01:40 PM
ChaseTruck754
Montana is talking bending the beams to correct for caster - which is what needs to be done of the ride height changes, and yes it's pretty tought to find anyone who does this anymore. If you wanted to find someone the best bet would be to try a big rig type shop as many of the medium duty 2wd trucks are on an i-beam front axle (solid axle - not split like out trucks) and they get adjusted the same way.
Us desert guys do the beam bending or pie cutting, welding and plating at home, but it's not something the average Joe would ever come close to messing with.
Old Dec 23, 2011 | 02:42 PM
bamaf150's Avatar
bamaf150
This is true but correct me if I'm wrong, aren't the newer super duty 2wds still using twin I beam, and if they are, shouldnt a Ford dealer be able to align/bend id needed these front axles? The last new Ford I looked at buying was still using twin I beam.
Old Dec 23, 2011 | 02:50 PM
ChaseTruck754
The newer twin i-beams (anything after 82 I believe) have ball joints in them & there are alignment cams out there for the ball joints that correct the camber up to a certain degree.
The other thing people do on the newer trucks is to drop all the pivot points (i-beams & radius arms) the same amount as you are lifting (ie. 2" lift coil gets pivot points lowered 2"). This idea can also be used on our trucks but it involves a bunch of custom fabrication
Old Dec 23, 2011 | 03:18 PM
jeepjinx's Avatar
jeepjinx
Old Dec 23, 2011 | 03:24 PM
montana_highboy
Originally Posted by jeepjinx
Bending the axle beams? Not gonna happen on my truck!
No need to be alarmed, that's the way it was/is done.
Old Dec 23, 2011 | 04:45 PM
ChaseTruck754
Haha - I love when people get all freaked out by the beam bending. It's been done that way for decades...
"Drop beams" for hot rods starting in the 50's up til today is one good example as well. It's a slightly different type of bending but similar principle.
Old Dec 23, 2011 | 05:03 PM
jgavac's Avatar
jgavac
Wouldn't dropping the back to match the front also work?
Old Dec 23, 2011 | 05:08 PM
ChaseTruck754
depends on what he does with the truck & the performance he wants out of it. That can work & is usually a bit easier/costs less.
Old Dec 23, 2011 | 05:11 PM
jgavac's Avatar
jgavac
Would it be as simple as taking a couple leafs out? Or would you have to get softer ones
Old Dec 23, 2011 | 05:13 PM
ChaseTruck754
If he isn't using the truck to haul heavy loads then a couple leafs can come out. If he is then a longer shackle in the rear would work. You have to be careful on this though as if you go too long then the thing hits the underside of the bed.
crisman
May 3, 2018 02:41 PM
achec
Nov 18, 2016 03:24 AM
beastieboy
Nov 8, 2013 10:47 PM
betrayz
Dec 29, 2008 12:09 PM
rbloodhound
Oct 23, 2007 09:44 AM
