dome light for pick up
Old Dec 22, 2011 | 11:16 PM
1978-BBB's Avatar
1978-BBB
hey does anybody know what bulb goes in the dome ( above rear window )of a 78 f-250? mine is missing, also has anyone ever noticed problems with theirs not working? i put a test light to and no power.... common problem?
thanks ,
Matthew
Old Dec 23, 2011 | 01:00 AM
moonley's Avatar
moonley
Yes, common. Assuming you already checked that the fuze is good it is probably the push-button switch located in the door jamb. Try wiggling it (switch) around while having someone hold the tester, if it blinks on and off it is probably just corroded and can be replaced easily.
Old Dec 23, 2011 | 05:43 AM
bigTRUCKdriver0786's Avatar
bigTRUCKdriver0786
The bulb is a 561 or 562 I believe, worked in my 76 F100
Old Dec 23, 2011 | 08:45 AM
WyoFlyFisher's Avatar
WyoFlyFisher
NAPA stocks them where I am, they are a common bulb. You can also order them and the cover here RockAuto Auto Parts
<input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Old Dec 23, 2011 | 11:27 AM
1978-BBB's Avatar
1978-BBB
ok thanks guys, i think i'm going to order the courtesy light kit that goes under the dash too and hook them all up together.
drew_myers
Sep 11, 2017 06:28 PM
askopp
Dec 14, 2006 02:04 PM
justinsinternet
1983 - 2012 Ranger & B-Series
Sep 3, 2004 11:42 AM
Eddie
Nov 2, 2001 09:37 PM
