Idle Problems
Old Dec 22, 2011 | 06:57 PM
Big-Green-1992's Avatar
Big-Green-1992
Idle Problems
First off i have a 1992 f150 with a 302. I just rebuilt it 2 months ago and a problem has surfaced. It won't idle worth a crap. It does alright in park or neutral however god forbid you put it in gear then she immediately looses Rpm's and stalls. Any Suggestions? If it doesn't stall it surges RPM's from 200-1400. The idle is set a little high at around 850.
Old Dec 22, 2011 | 08:41 PM
Edgethis's Avatar
Edgethis
Check for codes. Did you add anything to the motor when it was rebuilt?
Old Dec 23, 2011 | 08:25 AM
Big-Green-1992
everything 56 lift cam new pistons 3 in heads alot. I just replaced the alternator and it got worse.
Old Dec 23, 2011 | 12:33 PM
rla2005's Avatar
rla2005
You need a custom tune with all the work you put into that engine.
Old Jan 1, 2012 | 07:45 PM
Big-Green-1992
turned out to be the throttle position sensor. 40 bucks and good to go
Old Jan 1, 2012 | 07:51 PM
Edgethis's Avatar
Edgethis
Good to hear you got it fixed
morrigj83
Jan 28, 2011 11:28 PM
gregy
Aug 2, 2005 09:19 AM
rkent5469
May 29, 2005 01:40 AM
Jedi Apprentice
Jun 27, 2002 02:33 PM
