2002 ranger 3.0 a/t has code p1336
Old Dec 22, 2011 | 04:37 PM
caseyoerding's Avatar
caseyoerding
mil with code p1336 crankshaft/camshaft range performance i replaced cam. pos. sensor and synchro shaft cleared code but it came back after driving a couple miles mind you i dont have the alignment tool but i got a good eye lol the mil is not lit up on dash anymore but code still show up can someone please shed some knowledge i ordered the tool it wont be here til next week though thank you
Old Dec 23, 2011 | 08:21 AM
powersmoked's Avatar
powersmoked
if the tool does not take care of it....clean the connection on the Crank and if that does not do it I would swap out the crank.........on your Motor changing that syncro is maintenance anyways so no lose there....you might have saved your engine in the long run
Old Dec 23, 2011 | 09:43 AM
pawpaw's Avatar
pawpaw
If the CEL isn't lit, but the code is still stored, did you try disconnecting the battery B- cable for a few minutes, to clear the code????
Old Dec 23, 2011 | 10:49 AM
caseyoerding
thank you for the replies i bought the alignment tool it wont be here til next week i cleaned the connectors to both cmp and ckp before i went out and got the cmp and synchro ill try disconnecting the batt. and see if that gets rid of the code for good if not ill wait it out for the tool and redo it its only a 10 minute job anyways but lets say after i use the alignment tool the code still shows up i get a new ckp and the code still stays would the pcm be the culprit then i guess i could backprobe pcm pins and check for pwr and grnd does anyone have a diag. for pin locations on pcm
wrk4no1
Feb 21, 2010 08:42 PM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
dieselman2000
Feb 17, 2007 03:33 PM
gkzak28
1997 - 2003 F150
Sep 6, 2006 08:08 AM
