High Idle Mod on a E series Van
Old Dec 22, 2011 | 07:59 AM
mtnxtreme800's Avatar
mtnxtreme800
Has anyone done a high idle mod on a van, I found 2 DIY's in the tech files, but one is for use with 05-06 factory upfitter switches, which I don't think I have and the other is for 03-04 but it's for an F series. I have an 06 E350 series van, no switches I am aware of, and I'm figuring it's wired different than an F series.
Old Dec 22, 2011 | 09:45 AM
dchamberlain's Avatar
dchamberlain
Here is the PTO section of the 2006 Body Builders book. The wire colors and functions are the same, but the wires are in a different place.
Basically, you need to apply 12V to the Orange wire if you want SEIC (high idle with a locked torque converter), or to the Purple/Light Green if you want the Battery Charge Protect (high idle with no torque converter locked, up to 2400 RPM depending on battery charge).
https://www.fleet.ford.com/truckbbas.../2006/pto.html
Old Dec 23, 2011 | 05:38 PM
mtnxtreme800
The problem is i'm finding 2 or 3 different DIY's, I guess I need to look and see what colors wires I have in my bundle,as the orange wire is common to all, but the other wire, which is the Battery Charge wire, which is the one i want to use, is shown as 2 or 3 different colors depending on which DIY you look at including yours'. I also looked at the link you gave me which shows the wire bundle locations, it definitely helped as the location on a van, according to the link is outside under the hood, and all the trucks are under the dash, I would have never found it. I don't have these upfitter switches they talk abt. so I guess I have to wire my own switch with a keyed hot to the proper colored wire when switched on.
Old Dec 23, 2011 | 06:26 PM
jkudera's Avatar
jkudera
i have a factory high idle box controller that should work with your van
Old Dec 24, 2011 | 06:34 AM
mtnxtreme800
What does it consist of and how much do you want for it, is it from a van or F series. I've never heard of a factory high idle box controller, only upfitter switches.
Old Dec 24, 2011 | 08:24 AM
jkudera's Avatar
jkudera
it is a box and it plugs right in under the dash factory from ford. maybe 50 bucks shipped. i know there pretty expensive
Old Dec 24, 2011 | 09:02 AM
dchamberlain
The high idle box was designed for 7.3L engines. There won't be a place to plug it into a 2006, and he doesn't need it anyway. He just needs to hook power to the right wire through a switch.
EXbowtieguy
Nov 25, 2011 11:22 AM
FORDSDOWNER
Jan 5, 2008 02:52 PM
brianhea
Feb 9, 2007 02:48 PM
tex25025
Sep 18, 2006 06:17 PM
admorris
Jan 22, 2006 08:47 PM
