glowshift gagues reviews
Old Dec 20, 2011 | 08:53 PM
BRay09's Avatar
BRay09
I have an 06 F250 and was looking into gagues. Looks like glowshift are really good priced considering that one pyrometer from riffraff diesel cost what their whole kit does. Likes/dislikes? What 3-4 should I get?
Old Dec 20, 2011 | 09:26 PM
j4henry's Avatar
j4henry
I have boost fuel pressure and egt. Only complaint is sometimes at idle the boost gauge flickers when lights are on. But all in all worth the money
Old Dec 20, 2011 | 09:32 PM
bubba_78363's Avatar
bubba_78363
I got fuel, EGT, and oil pressure from them to monitor LPOP. Only complaint I have had from them is after about a week my fuel press started fluxing from about 15psi. Called customer service they sent me out a new sender no questions asked and have had no more issues. I would buy again, and would recommend as well. Like you said for the price you cant go wrong, and they look good as well.
Matt
Old Dec 20, 2011 | 09:38 PM
BRay09's Avatar
BRay09
Do you guys have the fuel pressure inside your cab? My buddy said its not really safe to have it like that, so he has his on his cowl.
I'm thinking fuel, trans temp and EGT for my three. Would the stock boost gague be okay when I get my powermax turbo? Or should I plan on another one
Old Dec 20, 2011 | 09:46 PM
bubba_78363
My fuel press is inside the cab on the pillar. It's and electric gauge and therefor no more harm than any other electric component inside your cab. If it were mechanical and you had had a fuel line running to the back of it then what your buddy is saying would make sense, but with electric no harm. Just my opinion of course. Also do you have a ScanGauge? If so then Trans temp can be read through there. If not then your 3 choices sound good.
Matt
Old Dec 20, 2011 | 09:56 PM
BRay09's Avatar
BRay09
I had the scan gauge but I didn't like it. I may buy one again and give it a shot to make an impression on me.
Old Dec 20, 2011 | 10:03 PM
Special Ed's Avatar
Special Ed
If you didn't like it don't buy it again. The Edge Insight is nice & worth your try.
Old Dec 20, 2011 | 10:05 PM
BRay09's Avatar
BRay09
I was just going to post that it looks tacky and there is really no place to mount it. Maybe if it had a window mount or something then it'd be better. The edge is pretty flashy and I may like that better.
Old Dec 20, 2011 | 10:31 PM
Special Ed's Avatar
Special Ed
The Edge Insight is the ****s! You won't regret it.
Old Dec 20, 2011 | 10:45 PM
jim6liter's Avatar
jim6liter
The flickering on the boost gauge is supposed to be fixed. I have an RA from them to get the updated gauge. Just need to pullit out and send it back.
Old Dec 20, 2011 | 10:48 PM
Fallguy2004's Avatar
Fallguy2004
I would buy GloShift again, nice product. I have 60psi boost, egt, and fuel pressure. Very happy.
Funny, I also had this problem about the boost gauge flickering back and forth when I have the headlights/dash lights on. At the same time I noticed my scan gauge showing at best mid to low 12 volts running. Soon after noticed 11.5-12 volts. Changed out the alternator to a 180 amp(14 volts running) and guess what, that boost gauge no longer flickers!
Old Dec 20, 2011 | 11:17 PM
bubba_78363
I do know that they sell a blend mount for it which allows it to be mounted above the rear view mirror, you might check amazon.com but I have no personal thoughts on the mount itself. I put an aftermarket radio in my truck and the scangauge fit perfectly in the cubby below the radio. I would highly recommend the scan gauge if not for the money, but mainly for the amount of info that can read from it.
Matt
Old Dec 21, 2011 | 05:38 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
Love my gauges, hate the tripod mount
Now that I have had my gauges for a while, they have worked flawlessly.
2 things that I would change, not dim-able, tripod blocks some view.
Yesterday while driving I realized that a mount on top of the speedo cluster would be perfect. It would put the gauges right in my view and not block forward view any.
Just my 2 cents from someone that has them.
Old May 31, 2013 | 12:27 PM
robbmax1's Avatar
robbmax1
Angry GlowShift Gauges
I have installed the GlowShift Boost, EGT and Trans Temp in my 2001 F250 Powerstroke. So far I've had to replace the Trans Temp one time and now the EGT has quit working for the second time. Both times they have quit just out of warranty. Very Cheap to buy, but very cheap quality as far as I'm concerned. I'm a Ford Trained Mechanic and they treat me like I don't know what I'm doing when trouble shooting the problem. Very dissatisfied with their Gauges and there Customer Service.
Old May 31, 2013 | 02:10 PM
Ian123's Avatar
Ian123
They seem to be hit or miss. I have a glowshift fuel pressure gauge and the sending unit failed after a month or two. They sent me a new one right away, so at least they have good customer service. Now the gauge seems to work when it wants to. Most of the time its alright but other days it will randomly read all over the place. I plan on going with isspro or autometer when I get the money
