1978 - 1996 Big Bronco
Fast Blinker
Old Apr 16, 2003 | 04:59 PM
Wakeboarder141's Avatar
Wakeboarder141
Fast Blinker
My blinkers both blink at about twice the speed as most cars. All the bulbs are good. It isn't a big deal, but is there a way to adjust this? Thanks.
Old Apr 16, 2003 | 05:36 PM
bronco cam's Avatar
bronco cam
Fast Blinker
Try replacing your blinker fuse. It is the big round one in your fuse box. That might fix it.
Old Apr 16, 2003 | 05:52 PM
mrwizard's Avatar
mrwizard
Fast Blinker
Get an electronic flasher unit, especially if you ever tow a trailer. The standard ones are thermal.
Old Apr 17, 2003 | 03:58 AM
greystreak92's Avatar
greystreak92
Fast Blinker
Sounds like someone may have replaced the signal flasher with a higher capacity version at some point in time. If you tow a trailer , the bi-metal originals tend to die quicker and replacing them with a higher amperage flasher will keep them from slowing down (or burning up) when you add the extra lamps with the trailer connected. But when the trailer is not hooked up, the flasher will cycle that much faster. I'd go in search of the correct flasher to replace the one thats in there.
Old Apr 17, 2003 | 06:09 AM
Wakeboarder141
Fast Blinker
Where do I find the flasher unit that you are referring to? I assume it is some device that controls the flashers? How can I get to it, and is it hard/expensive to replace? Thanks.
Old Apr 17, 2003 | 08:07 AM
Broncomule's Avatar
Broncomule
Fast Blinker
If you do any towing install a heavy duty flasher. If you do no towing install a standard duty flasher. There should be two flashers plugged into your fuse box. One for emergency flashers and one for direction flashers.
Old Apr 17, 2003 | 12:47 PM
alanscott's Avatar
alanscott
Fast Blinker
I think you may have that backwards. My experience has been that the original thermal type will flash faster with the extra draw from the trailer lights.
Old Apr 17, 2003 | 12:53 PM
Lookinfurfun's Avatar
Lookinfurfun
Fast Blinker
I agree.
The flasher is only a few $$$ at the local parts store.
Old Apr 17, 2003 | 02:41 PM
mrwizard's Avatar
mrwizard
Fast Blinker
The electronic flashers don't care how many bulbs there are. They flash the same with or without a trailer hooked up, and are supposed to last much longer. I think mine was still less than $10.
Old Apr 17, 2003 | 02:51 PM
Kemicalburns's Avatar
Kemicalburns
Fast Blinker
I have seen were a short in the system will cause the blinkers to flash faster then normal. I would check your wiring around the blinkers and see if maybe it has worn through and is touching metal
good luck
later
Old Apr 17, 2003 | 03:07 PM
treehugger36's Avatar
treehugger36
Fast Blinker
a little known fact is that you can actually over fill your signal fluid resevoir. You may have too much fluid... try purging your system, drain some and see if that works.
let me know if that helps
Old Apr 17, 2003 | 03:15 PM
maulsmasher's Avatar
maulsmasher
Fast Blinker
It's about $3.00 for a flasher fuse
Old Apr 17, 2003 | 03:20 PM
Lookinfurfun
Fast Blinker
LOL.......I guess that there could be air in the line too
Old Apr 17, 2003 | 04:26 PM
Wakeboarder141
Fast Blinker
Where the heck is the signal fluid resevoir?? I have never even heard of that.
Old Apr 17, 2003 | 06:37 PM
mrwizard's Avatar
mrwizard
Fast Blinker
It's right next to the age sensor that keeps the blinkers on forever on vehicles driven by people over 75 years old.
