1978 - 1996 Big Bronco
Fast Blinker
Old Apr 17, 2003 | 06:46 PM
Wakeboarder141's Avatar
Wakeboarder141
Fast Blinker
Ohhhh....THAT resevoir. I'll make sure to check that tomorrow
Old Apr 17, 2003 | 11:24 PM
broncr's Avatar
broncr
Fast Blinker
I had a buddy that had the trailer flasher on his Bronco. My wife thought the "frantic" flash fit his personality. I carry a spare unit (for when I'm trailering) - it plugs into the fuse box. Bottom line - did this "frantic" behavior just start happening - or did the vehicle come to you like that? If it came like that - it's PROBABLY just the flasher contol unit (like greystreak said). ($5 - any parts store - maybe even Wal-mart))
I'm pretty sure I've never checked my signal fluid reservoir. The rest of my "reservoirs" are OK (according to ME).
Old Apr 17, 2003 | 11:41 PM
greystreak92's Avatar
greystreak92
Fast Blinker
You guys have it right, I was writing in the wee hours. The additional lamps drawing current through the flasher unit causes the bimetal to heat up faster thereby causing the increased flash rate.
Old Apr 18, 2003 | 03:35 PM
Wakeboarder141
Fast Blinker
Checked my flasher fluid resevoir and that was the problem! Blinking at a nice, normal pace now. Thanks!
P.S I don't think the new $4 flasher unit hurt either
Old Apr 18, 2003 | 03:41 PM
Lookinfurfun's Avatar
Lookinfurfun
Fast Blinker
Since your local AutoZone doesn't like to pull codes for you, you should have at least asked them to check that blinker fluid.
tufftruck
Nov 10, 2016 12:54 PM
rossseger
Nov 3, 2014 02:09 PM
heatherc
Dec 19, 2012 08:59 PM
93 mix 'n match
New Jersey Chapter
Nov 12, 2011 02:46 PM
wyckedcombo17
Jul 25, 2011 01:23 PM
