auto hubs, left right/ side specific?
Old Dec 20, 2011 | 01:03 PM
tripcana's Avatar
tripcana
8th Gear
Hello, working on a friends truck and having problems with the automatic hubs. its a 93 F150, auto hubs, manual T-case. he did a brake job with another friend, says 4wd worked before, and now it doesn't.
front axles turn when selected to 4wd, but the hubs dont lock up and turn the wheels.
i disassemble the hubs to inspect them, and i can get the hubs to lock and unclock, out of the truck. when put back in the truck they wont engage.
i'm going to take them back out and clean them real good, but i had a question.
are the hubs side specific? is there a difference between left and right?
i'm wondering if the guy got the hubs mixed up when he was doing his brakes. if they unlock when in reverse, could they not lock if isntalled the worng way?
Last edited by tripcana; Dec 21, 2011 at 11:16 AM. Reason: corrected year from 96 to 93
Old Dec 20, 2011 | 01:52 PM
andym's Avatar
andym
The way that you unlock auto hubs is to go about 15 feet in reverse, so I would assume that they are side-specific.
Old Dec 20, 2011 | 08:19 PM
fonefiddy's Avatar
fonefiddy
No, they should work either side. Take the hub out and make sure they reassembled them properly. There is a washer with large slots that engages the hub. Also, the brake band, and plastic sleeve need to be clean and lubed
Old Dec 20, 2011 | 10:32 PM
tripcana's Avatar
tripcana
8th Gear
Is that washer the C washer in the diagrams? I didn't see that when I took it apart, but there was a circlip on the axle. I think there was a splined washer, then the cir clip.
I dont know if they are the same part or if I'm missing parts
Old Dec 20, 2011 | 10:58 PM
donnor's Avatar
donnor
"To lock or not to lock..."
Have you considered that this would be the ideal time to convert to manual hubs? Some years ago an acquaintance of mine tore up the front differential in a Dodge due to one so-called "auto" hub failing to disengage.
dn.
Old Dec 21, 2011 | 10:41 AM
fonefiddy's Avatar
fonefiddy
The washe I mentioned is unmistakable. It looks like a regular washer, with large"helicopter" blades. If you pull the hub
Old Dec 21, 2011 | 10:43 AM
fonefiddy's Avatar
fonefiddy
[QUOTE=fonefiddy;11180584]The washe I mentioned is unmistakable. It looks like a regular washer, with large"helicopter" blades. If you pull the hub, they should be obvious without removing anything else
Old Dec 21, 2011 | 11:13 AM
tripcana's Avatar
tripcana
8th Gear
im not sure i know what the "helicopter blade" washer is. from pictures, it looks like you have to take apart the hub body assembly apart to see it. i couldn't get the body assembly apart, i didn't want to break anything.
the first picture shows the C washer. to me the C washer is a circlip that holds the splined washer on?
the second picture shows something that looks kinda like helicopter blades, but looks like you have to disassemble the hub body assembly?
Old Dec 22, 2011 | 04:44 AM
fonefiddy's Avatar
fonefiddy
If You look at the drag sleeve, there are 4 notches. Look inside the axle hub, there should be a large washer with the "helicopter blades" that engage the notches on the drag sleeve.
I'd recomend getting a pair of snap ring pliers, and disassemble the hubs. It's much easier to get them clean and lubed. You need to remove 2 retaining clips and You can get them torn down. The inside one can be done with a small screw driver
Old Dec 22, 2011 | 08:31 AM
robertsblk70's Avatar
robertsblk70
Auto Hubs
After having issues with my Auto Hubs which never worked right even after being serviced I bought a set of Mile Maker manual hubs. Best thing I ever did for this truck. Ford had a really bad idea with their auto hubs.
Old Dec 22, 2011 | 11:19 AM
donnor's Avatar
donnor
"Locked or unlocked: That is the question..."
All of the Big Three (and others) jumped on board the "auto hubs" bandwagon to varying degrees; some earlier than others starting in the early 1970's. In their defense, they were making available a feature that a segment of their customer base wanted. Even after 40 years, though, there is still a segment [count me in] that still wants to be able to look at a hub and know its lock/unlock status.
dn.
Old Dec 22, 2011 | 02:56 PM
fonefiddy's Avatar
fonefiddy
I'd almost bet that over 90% of Peeps tha own a 4X4 have no idea how it works. They just want it to work, when They want it to work.
The auto hubs work very well, IF They're maintained. I've got 250K miles on mine. I jsut replaced one. It was due My neglegence more than anything. I did not service them last winter, and this spring I could tell there was something funcky going on with the one. I just kept driving and burned one down.
If Your a hard core 4 wheeler, I'd definately recomend manual hubs. But for the 90%+ of Peeps that use 4x4 10-12 times a year, the auto hubs are just fine. I prolly use 4x4 3-4 times a year. I use My 4X2 truck all summer, and never miss having 4x4
Turbostixxx
Mar 4, 2015 08:56 AM
Dbergeson
Nov 23, 2014 05:18 PM
rossgn
Dec 9, 2013 09:18 AM
93F250
Feb 11, 2009 12:40 PM
