Any of you guys swap the body from a wide frame (78/79) onto a narrow frame (Mine being a 75 F250 4X4)? I got a 1978 Body that is really good, and I want to put it on my Highboy Frame. Anyone ever do it and can tell me how I should go about this? I plan on a body lift, and I figure doing a body lift may also allow me to modify as needed.. Thanks guys.
finished one a month ago 77f250 2wd to 74 high boy 4wd. not bad a few extra things to change power booster / master , steering column, plan on the rear tail light harness being trashed misc hoses brake lines and a ton of new bolts. it took about a grand and 4 days to be up and running for me.
Well I found a guy on here in my search and all he did was drillt hrew the Transfer Case Crossmember for the cab and made gussets for his bed. I got the angle iron for the gussets, and I got drill bits,a s for wiring harness... well this trucks is getting STRIPPED and getting all new wiring.
