ENGINE COOLANT
Old Dec 19, 2011 | 09:31 PM
Rosson03's Avatar
Rosson03
ENGINE COOLANT
whats a good kind to use and is there any one that out proforms
Old Dec 19, 2011 | 09:41 PM
LivingLarge's Avatar
LivingLarge
Do a search for Ford Gold Coolant... Great stuff, will outlast your truck.
Old Dec 19, 2011 | 10:55 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
If you have a diesel, you need to run CAT ELC1 rated
Old Dec 20, 2011 | 03:35 AM
Stewart_H's Avatar
Stewart_H
The answer depends on what kind of engine you have.
That depends on what kind of engine he has.
That's ELC, as in Extended Life Coolant. And it's an ELC that's rated CAT EC-1, not ELC1.
Stewart
Old Dec 20, 2011 | 07:34 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
He has a V10...
Old Dec 20, 2011 | 11:32 AM
LivingLarge
Originally Posted by Toreador_Diesel
He has a V10...
Ford Gold, gasser for sure looking at his mods.
Old Dec 20, 2011 | 01:43 PM
Stewart_H's Avatar
Stewart_H
He has a list of mods?
Ok, I'm blind.
Stewart
Old Dec 20, 2011 | 02:47 PM
LivingLarge
Ok, I'm blind.
Stewart
No your over worked! TOR has you cleaning up the place!
Description: K&N air intake, BBK Dual 65mm throttle body, Jet Mass air flow, Jet spacer, Royal purple engine, Royal purple trans, Royal purple rear diff, Fitch Fuel Catalyst. took off my luggage rack, removed that big black rubber piece under the hood, ditched the running boards, took out the 3rd row seat and bass systeme, Around 13.2 MPG
sounds like a gasser, specially that 13.2 mpg.
Old Dec 20, 2011 | 03:14 PM
Stewart_H's Avatar
Stewart_H
Yeah, especially with the throttle body and mass air flow mods.
Where in the heck did you see that?
Stewart
Old Dec 20, 2011 | 03:22 PM
LivingLarge
Stewart
Clicked on 2000 excursion next to Avatar...
It's all good brother!
Old Dec 20, 2011 | 03:40 PM
Stewart_H's Avatar
Stewart_H
Ok, I'm spoiled. I look for sig listings.
Stewart
Old Dec 24, 2011 | 03:24 PM
Rosson03's Avatar
Rosson03
its good to be back
Sorry took me so long to get back i got suspended.
anyways thanks guys..... anyone has tried the purple ice thing to. i am about to put in jets 180 degreese therm and going to flush out my coolent and start from bar none.......
while i was being suspended i replace my blower motor it rusted out at the bottom has anyone had that problem and i got it done cheep and it was hard to find the rubber gasket.
Old Dec 24, 2011 | 04:38 PM
tdappleman's Avatar
tdappleman
I haven't used the Ice but do use the Redline Water Wetter. Cheap additive and certainly causes no harm. The surface tension is similar to what you'll see if you boil a pot of water - if the water is boiling then the pot has areas where the water doesn't contact it. The additive reduces that tension and allows the coolant to fully contact all of the coolant tracts. Theoretically the coolant should raise the boiling point and so surface tension should be at a higher temperature but all engines have hotter areas where this can certainly make a difference.
str8sixman
Jun 28, 2016 07:46 AM
mmenzies
Jul 3, 2011 04:07 PM
D8chumley
Sep 3, 2008 09:29 PM
OhioRiverCigarette
Mar 29, 2008 05:32 AM
unluckylow
Jul 25, 2005 08:59 PM
